GSR JDM compresion ratio
Old Jul 10, 2004 | 02:16 PM
Simpson's Avatar
Default GSR JDM compresion ratio
what is the compresion for the pistons on the GSR?
Old Jul 10, 2004 | 02:34 PM
mugenracer's Avatar
10.6 for JDM B18C SiR/SiR-G pistons
Old Jul 10, 2004 | 02:39 PM
Simpson's Avatar
Default Re: (mugenracer)
so if i put some type r pistons ill have a noticeable diference?
Old Jul 10, 2004 | 04:29 PM
tommymoose's Avatar
Default Re: (Simpson)
It wouldnt be worth the work to just put in Type-R pistons. With a compression ratio of 11.1 : 1 you wouldnt be gaining that much. You'd be better off getting a higher compression piston (maybe 12:1) because the difference would be more noticable.
Old Jul 10, 2004 | 04:43 PM
Simpson's Avatar
Default Re: (tommymoose)
i cant run 12.1 with 95 octane gas
Old Jul 10, 2004 | 05:36 PM
mrmonk's Avatar
95??? damn i can only get 93 around where I live.
Old Jul 10, 2004 | 08:07 PM
thegsrman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommymoose &raquo;</TD></TR><TR><TD CLASS="quote">It wouldnt be worth the work to just put in Type-R pistons. With a compression ratio of 11.1 : 1 you wouldnt be gaining that much. You'd be better off getting a higher compression piston (maybe 12:1) because the difference would be more noticable.</TD></TR></TABLE>
i think his gains would be noticable with the type r pistons and more so with the jdm type r pistons (11.6:1 i believe)since he would be raising his compression ratio a full point or point and a half. other mods on his car would help also, like cams,etc. ifeel if he goes 12:1, he would be pushing it a little too much.
Old Jul 10, 2004 | 08:36 PM
tommymoose's Avatar
Default Re: (thegsrman)
Oh okay. And if he can't get the jdm ones for whatever reason would it be a good idea to get the USDM pistons and a thinner head gasket to up compression?
Old Jul 10, 2004 | 08:58 PM
thegsrman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommymoose &raquo;</TD></TR><TR><TD CLASS="quote">Oh okay. And if he can't get the jdm ones for whatever reason would it be a good idea to get the USDM pistons and a thinner head gasket to up compression?</TD></TR></TABLE>
usdm type r pistons should give him around 11:1 compression ratio. with a thinner head gasket, it might be more, but i'm not sure how much. personally i'm not a fan of going with thinner head gaskets, but that's just me. i have'nt heard of anyone having bad experiences with them though.
you can check out different compression ratios on
http://www.c-speedracing.com
Old Jul 10, 2004 | 09:27 PM
Simpson's Avatar
and what if i buy a usdm type r pistons and put a thicker gasket?
Old Jul 10, 2004 | 09:31 PM
thegsrman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Simpson &raquo;</TD></TR><TR><TD CLASS="quote">and what if i buy a usdm type r pistons and put a thicker gasket?</TD></TR></TABLE>
like i said check out http://www.c-speedracing.com and you'll see.
Old Jul 10, 2004 | 09:32 PM
Simpson's Avatar
do you have msn?
Old Jul 11, 2004 | 06:52 PM
tommymoose's Avatar
I've seen the spoon and mugen head gaskets advertised to increase compression by about .3 .... so that would mean with USDM ITR pistons and the headgasket you would be getting about an 11.4:1 cr
teggy!
Mar 25, 2012 12:13 PM
stonet149
12
Nov 2, 2008 09:29 PM
team 15
Jun 22, 2007 03:49 AM
Vpenh
Jul 30, 2006 12:26 PM
Shane54
Sep 21, 2002 09:55 AM
