question about vtec?
Old Jul 10, 2004 | 01:05 PM
91_civicsi's Avatar
Default question about vtec?
okay so i have a b16 in my car, only 225 kms on the motor after the rebuild and did some more mods, headwork and a few other things
im wondering why now my car kicks vtec at 5200 rpms instead of 4800 last year, i do have gsr cams now, but im still running the pr3 ecu, could this be why its kicking i at 5200? gsr cams from a 94 integra gsr
it also feels as if my car is slower then last year and that was on a bone stock b16,, its more built up now and has some headwork etc,,,, why is this
coiuld the motor not be fully broken in yet, with only 225 kms (obviously its not FULLY broken in) but i mean why is it slow, i lost to a stock b16 last night by like a couple cars
Old Jul 10, 2004 | 01:08 PM
wtsexton's Avatar
I do believe the stock pr3 cross over is 5200.
Old Jul 10, 2004 | 01:16 PM
91_civicsi's Avatar
Default Re: (wtsexton)
its 4800 for a sir 88-91
Old Jul 10, 2004 | 02:03 PM
eda6's Avatar
Did your ecu get chipped?
For 1st gen b16 vtec is at 4800.
With the new chip vtec point usually gets increased.
My vtec crossover was 5200 with a new chip.
It gives the motor a chance to build up more oil pressure before
vtec engages.
Old Jul 10, 2004 | 02:08 PM
EL Vap133's Avatar
Default Re: (eda6 hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hb &raquo;</TD></TR><TR><TD CLASS="quote">Did your ecu get chipped?
vtec engages.</TD></TR></TABLE>
Beat me to it.
Old Jul 10, 2004 | 02:15 PM
91_civicsi's Avatar
no mang, stock pr3, getting it chipped next week, but im still just wondering why it would chang all of a sudden
maybe my stock tach is out???
but wouldnt it be better for vtec to engage earlier and pull right up to 8000rpms? thats what i udnerstand and that is why the mugen chip is so good
but why is it slower then a stock b16, anyone have any ideas ?
Old Jul 10, 2004 | 02:32 PM
eda6's Avatar
Default Re: (91_civicsi)
get a new chipped ecu and see if the problem goes away.
I would not be running a stock ecu with your mods.
Modified by eda6 hb at 11:42 PM 7/10/2004
Old Jul 10, 2004 | 04:30 PM
91_civicsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hb &raquo;</TD></TR><TR><TD CLASS="quote">get a new chipped ecu and see if the problem goes away.
Modified by eda6 hb at 11:42 PM 7/10/2004</TD></TR></TABLE>
haha i kno man, next week, hopefully that helps somewhat
i got port n polish, 3 angle, valve guide seals replaced, and chopped 12 thousand degrees.
gsr cams
i/h/e
new bearings/rings
8 puck clutch
lightened flywheel
that should beat a stock b16...
Old Jul 10, 2004 | 04:31 PM
4gCRX's Avatar
My PR3 kicks VTEC in at 5300: http://b16a.honda-perf.org/care.html
I have heard good and bad about the mugen program so check it out thoroughly.
Did you tune the motor after the cam install? Adj. Cam gears? Timing?Fuel?
Check these dyno's out...click on the last one labeled 1992B16A, it has an 89b16 with gsr cams. Scroll down and check out where the motor stopped making power and notice the rev limiter...8200rpm:
http://www.importreview.com/d_1.6.html
Old Jul 10, 2004 | 04:43 PM
91_civicsi's Avatar
Default Re: (4gCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gCRX &raquo;</TD></TR><TR><TD CLASS="quote">My PR3 kicks VTEC in at 5300: http://b16a.honda-perf.org/care.html
http://www.importreview.com/d_1.6.html</TD></TR></TABLE>
yea im gonna get cam gears, fpr, and aem fuel rail next i think, then tires :0
you think its a good idea to get that stuff, will it be worth it?
i hope i can hose b16s with my new chips, getting a mugen, toda, and spoon onez
i should be able to walk on stocker b16s, but for some reason i cant
im putting money on because its only got 225 kms on teh motor, maybe it just needs to be broken in more...
i dunno
what you guys think?
Old Jul 10, 2004 | 04:44 PM
4gCRX's Avatar
From what I've been reading definitely cam gears and fpr...not sure about the fuel rail. Not sure as in I haven't read much about them.
What car do you have this motor in and what car beat you?
Old Jul 10, 2004 | 04:48 PM
91_civicsi's Avatar
Default Re: (4gCRX)
its in a 91 honda civic si hatchback with full interior, no subs or anything
the car that beat me is a bone stock b16 in a 91 civic si hatch same year , no subs or anything but NO EXHAUSt so he has mad back pressure
i have an ls transmission where as he has an actual b16 transmission
i know you guys are all going to say oh its because of your transmission but thats not the case, we have raced many times before, he is a buddy of mine, we had a fued last year when we were both STOCK,,, he hasn't done any mods this year but i have, and last year i could beat him by 1 car length and i had my ls transmission and he had his b16 transmission
so im not sure why im losing...
and i also lost to another b16 yesterday, but that one was in a 90 civic dx
Old Jul 10, 2004 | 05:01 PM
wpgcivic's Avatar
join the family adam, maybe your last bottom end had something done to it
Old Jul 10, 2004 | 05:02 PM
4gCRX's Avatar
I'm looking at a dyno of a b16a; stock cams vs. Crower 401's...hotter cams than yours. The 401's didn't start to "beat" the stock cams until mid range...80hp @ 4500rpm.
91_civicsi's Avatar
Default Re: (wpgcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">join the family adam, maybe your last bottom end had something done to it</TD></TR></TABLE>
it didnt' we looked
Old Jul 10, 2004 | 05:03 PM
91_civicsi's Avatar
dont get me wrong it still ****** hauls and would rape you sean :0 but its not as quick as i thought it would be
i think i'll be able to beat my buddy in his sr20det 240sx
we'll have to see though
Old Jul 10, 2004 | 05:04 PM
wpgcivic's Avatar
think you'll beat chris now
Old Jul 10, 2004 | 05:05 PM
B2FiNiTY's Avatar
Default Re: question about vtec? (91_civicsi)
Car could need tuning. Why are you racing it with so little miles?
Old Jul 10, 2004 | 05:07 PM
4gCRX's Avatar
"Car could need tuning. Why are you racing it with so little miles?"
Good point, have to let the valves seat properly or you'll be losing power
91_civicsi's Avatar
Default Re: question about vtec? (B2FiNiTY)
thats kms lol , i dunno cuz its not burning oil and running mint, i've asked a few ppl and they said it should be good
i was also told if your gonna drive it hard, then drive it hard from teh beginning
Old Jul 10, 2004 | 05:09 PM
wpgcivic's Avatar
or not, you do PROPER break in and then you giver
Old Jul 10, 2004 | 05:10 PM
91_civicsi's Avatar
it is broken in, its running mint
Old Jul 11, 2004 | 10:18 AM
91_civicsi's Avatar
anyone else have any ideas?
my motor is leaking oil too, its coming from where the tranny is,, but its engine oil ;s i dunno mang!
hondaon18's
43
Oct 7, 2007 12:56 PM
xxwhixx
Nov 7, 2005 12:23 AM
kinvid22
Apr 24, 2005 04:56 PM
crexer
Mar 26, 2005 11:24 PM
turtleb16a
Aug 2, 2002 10:39 AM
