DOHC ZC Distributor - What OE Honda Coil Can be Used to Replace the Stocker?
Old Jul 10, 2004 | 12:54 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default DOHC ZC Distributor - What OE Honda Coil Can be Used to Replace the Stocker?
A friend of mine has a DOHC ZC and he thinks the coil has gone out in his distributor. I'm not sure which coil he needs to order.
Also I don't know if his distributor has the crank sensor in it, or if it's the type with the external sensor on the front cam like some older D16A1s had. Does this make a difference?
I'm thinking it'll end up being like an 89 Integra coil, but I'm not sure.
TIA.
Old Jul 10, 2004 | 01:01 PM
Nerologic's Avatar
89 coil will work(d16a6), the whole distro will work also....
Old Jul 10, 2004 | 07:55 PM
t0eKnEe's Avatar
Default Re: (Nerologic)
I have a coil from my 89 teg distributor from my zc motor. I upgraded to an external one so I have no use for it anymore. Let me know if your looking for one.
Old Jul 10, 2004 | 08:05 PM
mynameistin's Avatar
as for the coil he can use the crx hf or crx si coil they both work and if he wants the whole dizzy get an 88-89 teg dizzy. the external sensor just look if its odb0 then he shouldnt have one but if he is odb1 then he will, on the exhaust cam there should be a sensor sticking out just like the dizzy otherwise there will bea black cap. hope that helps
h22_crx
Mar 19, 2006 12:20 PM
Ahks
Feb 11, 2006 08:24 AM
Sean-Ratchford
Feb 17, 2005 02:40 AM
JapJunkie
Apr 1, 2004 05:14 PM
VtecKiDD
Oct 1, 2003 08:07 PM
