spark plugs are black...turbo sputters top end
Old Jul 10, 2004 | 12:05 PM
buda18's Avatar
Default spark plugs are black...turbo sputters top end
setup: gsr turbo, hondata, walbro 255, 550cc injectors, 3"dp (running open DP)
the car was tuned and ran fine for a couple of days, then i had code 43 light up. its not constant, comes on sometimes and sometimes it doesnt.
i checked my spark plugs today and they were black with the electrodes being white so i changed those out and went out for couple runs, pulled strong the first two runs then it seems like the turbo just dies but sputters top end. and the idle isnt to smooth either.
those are all the symptoms i can think of right now. please let me know what you think the problem could be
Old Jul 10, 2004 | 01:10 PM
beepy's Avatar
Default Re: spark plugs are black...turbo sputters top end (buda18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">with the electrodes being white</TD></TR></TABLE>
Running lean.
Old Jul 10, 2004 | 01:54 PM
Drew Peacock's Avatar
Whats the CEL mean? Fix that first of all, I would tend to think it misfiring up top hence the fouled plugs. WHat have you gapped them to?
Old Jul 10, 2004 | 02:43 PM
buda18's Avatar
Default Re: spark plugs are black...turbo sputters top end (turbozxi)
the code means "fuel supply system"
im running the ngk R5671A-9 plugs, stock gap
Old Jul 10, 2004 | 02:44 PM
illicon2003
Guest
Posts: n/a
you are running rich I think.
Old Jul 10, 2004 | 03:33 PM
Full-Race Geoff's Avatar
cahnge your plugs, put new ones in, and get a better tune
Old Jul 10, 2004 | 03:50 PM
buda18's Avatar
Default Re: spark plugs are black...turbo sputters top end (Full-Race Geoff)
ok i was just in my garage and i noticed that where my car was sitting, under the DP there are black spray stains on the ground as if the dp was spitting something out. maybe excess fuel?
it cant be the tune can it? everything was working properly after the tune
Old Jul 10, 2004 | 03:59 PM
black means your car is way too rich. You need a fresh set of plugs (fouled plugs dont burn clean) and ou need a better tune so that you dont run so rich that you continue to foul plugs
Old Jul 10, 2004 | 04:50 PM
Suprdave's Avatar
Default Re: spark plugs are black...turbo sputters top end (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">
Running lean.</TD></TR></TABLE>
Wrong Sir...the fuel ring of a spark plug is the top of the thread.
Old Jul 10, 2004 | 07:13 PM
Gap them down try 0.030 it may just cure your problem
Old Jul 11, 2004 | 07:42 AM
illicon2003
Guest
Posts: n/a
are you sure it's not oil leaking out of your downpipe....if so, that means your seals might be blown on your turbo. Therefore you aren't actually forcing air into the motor, which can explain sputtering high end (I'm guessing, I'm not 100% sure about how hondata works) because now there's no air to accommidate for that fuel. That's just my guess I'm not a mechanic
Old Jul 11, 2004 | 11:13 AM
buda18's Avatar
Default Re: (illicon2003)
i dont think its oil, because i can rub the residue off the ground and it doesnt smear or anything. is there any other way to check and see if the seals are blown?cause thats kinda scary
i dont know too much about the affects of a bad o2 sensor, but from what i've gathered, people are saying that a lot of times code 43 means a bad o2 sensor, could a bad o2 sensor make it run rich?
turbozxi - do you know what they're originally gapped to?
Old Jul 11, 2004 | 12:28 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buda18 &raquo;</TD></TR><TR><TD CLASS="quote">the code means "fuel supply system"
im running the ngk R5671A-9 plugs, stock gap</TD></TR></TABLE>
For what you are running, these are too cold of a plug. Try a 7 series and gap at .028.
And follow what Geoff said.
Old Jul 11, 2004 | 08:19 PM
Default Re: (buda18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buda18 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think its oil, because i can rub the residue off the ground and it doesnt smear or anything. is there any other way to check and see if the seals are blown?cause thats kinda scary
turbozxi - do you know what they're originally gapped to?</TD></TR></TABLE>Nah not sure for those plugs but regapping them is definitely worth ago , a bad O2 or a check light of any kind will make you run rich. I would agree thats those plugs are a bit to cold for your setup as well.
Old Jul 29, 2004 | 09:47 PM
Sohc Driver's Avatar
Default Re: (turbozxi)
try swapping out for bkr7e plugs...and see how those work out for you.
Khoi
BanzaiBeast
Apr 20, 2012 03:23 PM
stockb18c
Jun 4, 2009 09:08 PM
ejmatzell
May 9, 2006 07:00 PM
MOVE OVER
Oct 4, 2005 04:31 PM
missionaryrider
Sep 18, 2005 08:36 PM
