where is that damn service connector?!?!?!?!
Old Jul 10, 2004 | 10:00 AM
EG6 SiR's Avatar
Default where is that damn service connector?!?!?!?!
Im trying to look for the service connector on a 2001 Civic LX. Cant seem to find it, so I called honda and they said passenger side under the carpet. Well there is nothing there. Can someone help me! Ahhhhh!
Old Jul 10, 2004 | 10:19 AM
TwistedSI's Avatar
If it is the same as most EK's it is behing the passenger side kick panel. In my EM1 it is in a green harness holder thing right next to the ECU.
Old Jul 10, 2004 | 10:33 AM
EG6 SiR's Avatar
Default Re: (TwistedSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwistedSI &raquo;</TD></TR><TR><TD CLASS="quote">If it is the same as most EK's it is behing the passenger side kick panel. In my EM1 it is in a green harness holder thing right next to the ECU.</TD></TR></TABLE>
no, its not there. I know where the eks and egs are at I just cant find this one. There is no kick panel, just carpet and when I took the carpet out it was just the frame. So not even the ecu is on the passenger side. But thanks for the reply. Anyone else? Thanks!
Old Jul 10, 2004 | 12:25 PM
DudeRick's Avatar
Default Re: (EG6 SiR)
On my sons civic it was Passenger side under the upper carpet, but very high up on the right side...
Old Jul 10, 2004 | 12:28 PM
Bambooseven's Avatar
i did a tach install on one and it's ECU was all the way in front of the passenger side, where the passenger would put his/her feet. the service connector might be up in there?
Old Jul 10, 2004 | 08:48 PM
97dxnut's Avatar
Default Re: (Bambooseven)
In my ek its actually on the driver side at the bottom, kind of under the dash all the way to the left.
Old Jul 11, 2004 | 10:43 PM
EG6 SiR's Avatar
Default Re: (97dxnut)
thanks for the replies guys, but the diagnostic port/service connector ended up being on the driver side under the center console. I guess the OBD-IIb doesnt have the service connector that you can just jump. It had the diagonostic port that requires a scanner to plug in. I had to rent the autozone OBD-II scanner to get the code out of it. Thanks!
Funanin
Dec 28, 2007 10:19 AM
vladd
Dec 15, 2006 01:26 PM
ludekid4323
Aug 25, 2006 07:01 AM
solohatch
Aug 4, 2005 04:26 PM
sharkey65a
Jul 1, 2003 04:32 PM
