temp. gauge doing odd things?
OK, its really only doing one odd thing. sometimes when I shut the car off, the gauge will go all the way up and just stay there until I turn the car back on. when the car is on, it reads fine. Its just when the car is off, sometimes is goes all the way up. does anybody have any clue why? I have an 89 DX with a ZC swap. I've had the swap for about a year. I was told it could be a short. any clues? sometimes the gauge will also rise when I'm driving, not all the way, but half to 3/4. it seems like its rising to fast, it just shoots up. could the sender be bad? I've had my car heat up before and it defenitly seems like it is going to fast. thanks
OK, more info to help track down my problem. as I'm driving the temp. gauge goes up, I thought it was just running hot, but now I'm not sure. the gauge moves when any kind of power is used, like when I use my turn signals, or brakes. the turn signals make the gauge go up and down slightly, and the brake makes it go up a little. also anything else that draws power, like the heater, headlights, etc. I checked the harness's going into the cluster and there nice and tight. I checked all my underhood grounds, I'm lost. Also sometimes when I turn my key to ACC. the headunit blinks. and when I turn the key to where the lights come on the dash, then turn it off, the battery light stays on. its very faint then it clicks off, I can hear a clicking noise. it's only done it once or twice since these problems have started. could it be something inside the alternator? sorry about making this so long, but I have to figure this out.
Yeah, I probably could. I'll give that a try, but it sounds like there maybe something else wrong. could something be wrong with the alternator to cause this?
try a different sending unit, should be under the distributor and a little to the left, it is very small and has shiny terminal on it. it varies resistance in the circuit so if it is shot it will provide wrong resistance causing the gauge to give whacky readings. I just had to do the same thing to my car. 91 civic dx, now the gauge is steady at 1/3 so try that. good luck.
Dmascarenasp
Honda Civic (2001 - 2005)
Mar 14, 2016 11:15 AM
Alex Ely
Mar 28, 2015 09:16 AM
