Car runs like shit after my paint job.
Old Jul 10, 2004 | 01:30 AM
fluke83's Avatar
Default Car runs like **** after my paint job.
I just got my car back today. A friend of mine painted it for me. I could hardly get the car home, it wouldn't run for ****. I had it at about 6 grand and it would hardley be moving. I took it to my mechanic who doesn't really work on imports that much and all he could tell me was pretty much that it sounded like only 3 cylinders were working most of the time. (lot of help...yunno) Any body have any advice. My friend said the only thing he did was unplug the battery and didn't touch anything else when he sprayed it.
Old Jul 10, 2004 | 01:32 AM
thaiphob's Avatar
Nikon!!!
Default Re: Car runs like **** after my paint job. (fluke83)
did you make sure all your spark plug wires are tight?
Old Jul 10, 2004 | 01:36 AM
fluke83's Avatar
Default Re: Car runs like **** after my paint job. (thaiphob)
yeah, first thing i checked
i mean my mechanic didnt really know what to say so ..... what the ****?
Old Jul 10, 2004 | 05:12 AM
Cliffjumper2's Avatar
maybe your friend took it for a joy ride and burnt out your clutch or motor
no really, what are the symtoms?
Is it slipping, hesitating, etc....
check your air intake and exhaust, make sure there isn't any bad overspray; short of that, I don't see how a paint job would make your car run bad.
one more stupid suggestion: maybe he put several coats on, and the car just weighs more now......making it feel sluggish...........j/k
in all likelihood, it's just a coincidence, and your car needs a tuneup
Old Jul 10, 2004 | 06:06 AM
bdkrma's Avatar
"I took it to my mechanic who doesn't really work on imports that much"
Why's he "your" mechanic then??Maybe the car was running when it was painted and now theres paint clogging the filter? Your friend probably has the answer for you...not anyone in here
Old Jul 10, 2004 | 06:12 AM
..::91TEG-G2::..'s Avatar
Default Re: Car runs like **** after my paint job. (bdkrma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdkrma &raquo;</TD></TR><TR><TD CLASS="quote">"I took it to my mechanic who doesn't really work on imports that much"
Why's he "your" mechanic then??Maybe the car was running when it was painted and now theres paint clogging the filter? Your friend probably has the answer for you...not anyone in here</TD></TR></TABLE>
maybe works on the family's big blocks
Old Jul 10, 2004 | 08:30 AM
SMZ GSR's Avatar
Default Re: Car runs like **** after my paint job. (..::91TEG-G2::..)
How about taking it to a mechanic that knows imports?
fluke83's Avatar
I live in small town West Virginia and I'd have to drive over 2 hrs to an import mechanic. The guy who painted my car is 20 years old same age as me and he's very unexperienced. Don't get me wrong he's good at painting but anything else with cars....ehhh. The idiot did spray my exhaust though could that have anything to do w/ the prob. I kinda don't want to drive 2 hrs in a car that hardly runs plus I'd like to let the car set in a my garage until I'm allowed to put a coat of wax on it. Before bugs are hitting it a 70mph.
Old Jul 10, 2004 | 09:03 AM
Greenery18's Avatar
Do a compression test and a leakdown test on your engine.
Old Jul 10, 2004 | 09:17 AM
Muckman's Avatar
Moderator in Chief
Maybe they painted the inside of your engine?
Old Jul 10, 2004 | 10:12 AM
swanny's Avatar
Default Re: Car runs like **** after my paint job. (Muckman)
Masking paper in intake?
Old Jul 10, 2004 | 10:17 AM
TurboTeG4's Avatar
Default Re: Car runs like **** after my paint job. (xy swany)
What I think is that your so called friend took it for a joy ride and cracked a piston etc. etc. , you should have been aware of you mileage. If you dropped it off fine and now its screwed your friend is holding something from you.
Old Jul 10, 2004 | 10:26 AM
99REDGSR1's Avatar
Default Re: Car runs like **** after my paint job. (Greenery18)
Thats what i think
Old Jul 10, 2004 | 10:27 AM
99REDGSR1's Avatar
I would also do a compression test
Old Jul 10, 2004 | 10:29 AM
b18integraracer's Avatar
i think you should clean your air filter and check the throttle body for any over spray or clogging because of the over spray. also check the cap and rotor.also check the spark plug wires, plugs.it could also be that you burned out the cylinder.go to a import mechanic
Old Jul 10, 2004 | 10:40 AM
Teggsr2120's Avatar
Default Re: Car runs like **** after my paint job. (b18integraracer)
If he doesnt know what the hell he is doing maybe its not a smart idea to let him do it.
Old Jul 10, 2004 | 11:49 AM
rwaggie's Avatar
Go and check all of your grounds on the car and the engine bay. If he disconnected them and painted he either forgot to reconnect, or the paint layer is causing a poor connection.
Old Jul 10, 2004 | 12:17 PM
Sack Master's Avatar
Default Re: (rwaggie)
I don't give a rats *** if your mechanic doesn't work on imports. If he is a mechanic he can at least diagnos possible problems. Maybe he doesn't understand how vtec works but that doesn't mean anything. If he is a mechanic that knows how fuel injected cars operate he can work on it. They are all basically the same. It is still an internal combustoin engine. If he has no clue how fuel injection, electronic ignition systems, or computer controlled cars in general work then you need to find a mechanic that is not stuck in the 1970s.
Old Jul 10, 2004 | 12:24 PM
.water's Avatar
the best thing u could do was remember what was ur mile on ur car....so after done paiting u can see someone was driving or not...dont u think??
Old Jul 10, 2004 | 12:51 PM
Ti3d in's Avatar
Default Re: Car runs like **** after my paint job. (SpoonKillerB)
It's most likely the grounds.
Old Jul 10, 2004 | 01:20 PM
speedracer9k's Avatar
is there a CEL because your car runs like ****?
Old Jul 10, 2004 | 01:38 PM
RallyRedGT-V6's Avatar
aren't you supposed to wait like 2 months before you wax it?
i just got mine done professionally and he told me to wait at least 2
Old Jul 10, 2004 | 01:59 PM
SIK IN DA HED's Avatar
New User
sounds like your friend is an ******* and is lyin to you. probably drove it around and mashed the heck out of it til it broke somethin.
Old Jul 10, 2004 | 02:18 PM
slo2kgsr's Avatar
Default Re: Car runs like **** after my paint job. (SIK IN DA HED)
I would definatly check the grounds first. Also, a friend of mine had his car painted and they covered his filter with overspray (he had a CAI) that also could be a problem.
Old Jul 10, 2004 | 02:19 PM
xteg95's Avatar
well if you think its running on only 3 cyliinders id take it somewhere or if you can do it yourself...have a compression tests done, best way to find out.
