Limp Mode??????????
I just change the timing belt on a 01' civic LX and when I started it up, all was good. I took it for a drive and it was good for a while, then all of a sudden check engine light comes on and puts me into limp mode. It wont let me go past 3k rpm due to limp mode. I reset the ECU and CEL went away for a while then came back and put me in limp mode again. Im think it has something to do with the CAS or maybe my timing is off a little. I gotta check the CEL and the timing tomorrw cause its late right now. I just want some input before I check it out in the morning. Maybe there is something else I should check. Also do the 01' civics have the service connectors like all the other civics. Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtlecx92 »</TD></TR><TR><TD CLASS="quote">that happened to me once, the damned gas cap wasnt screwed in tight enough
but at least i learned</TD></TR></TABLE>
no, it cant be my gas tank cap cause I never touched it, but thanks anyway!
but at least i learned</TD></TR></TABLE>no, it cant be my gas tank cap cause I never touched it, but thanks anyway!
AllMotorHB
39
Sep 24, 2010 12:41 PM
4dek
Jul 6, 2008 10:51 AM
