turbo coupe civic
Old Jul 9, 2004 | 07:45 PM
XxKingZofPaki03x's Avatar
Default turbo coupe civic
Hey wussup i got a 2000 honda civic ex with 57,000 miles on the shell and 12,000 miles on the new set-up, 5 speed, clean title. This car has almost everything changed on it. The car is a LS V-TEC
The car on the outside has the following si lip,si wing,carbon fiber hood,snowflake style rims in black, hood locks.
The cars has an si transmission, and i also installed a brand new ACT XT-R kit in there which is a 6 puck.
The car on the inside has the following pyrometer gauge,boost gauge,rpm tach,apex i avc-r, si clusters, many indaglo colors,air/fuel ration gauge, oil gauge, kenwood head unit, fire extinguisher, and aluminum billet flors and custom aluminum by cup holder area. If you buy boost control for this car i know it is capable of more than 350 hp...
The cars engine has the following Integra ls block,civic si head, endyn turbo pistons, ls eagle rods, , blue printted block, ls v-tec gasket, ls v-tec conversion pack, oil filter adapter, oil line, r&r block, turbonetics turbo t3/t4 hybrid polished, turbo manifold ss tubular, spearco intercooler with a 3.5" core, 550 cc injectors, tial 40mm westgate, tail blowoff valve, down pipe, custom aluminum charge pipe, silicone houses and turbo clamps, oil pan, and computer mounted on insdie of the car which is an odb1 with hondata chip and connected to a hondata computer. from the honda dealership i also purchased 3 sleeve se, 1 damper and gear.
The car has the kenwood headunit that is attached to new kenwood and rockford speakers, and they are attached to a 800.4 watt rockford fostgate amp and the whole trunk is dynomatted.
I do have all the receipt for all the engine mods and i do have some of the other receipts. the reason i am selling this car is because i need money for college and bills. i was gonna sell the car for 13,500 but there is a dent in the rear quater panel so i think it would b reasonable if i made the car a bit cheaper and $11,000 flat.
thanks for your time and cooperation, you can im me at paktyson or email me at paktyson@aol.com
email me and i will send you pics.
XxKingZofPaki03x
Jun 29, 2004 07:01 AM
