are the windows on all model crx's the same?
Old Jul 9, 2004 | 07:37 PM
bluecrxsi's Avatar
Default are the windows on all model crx's the same?
some girl saw my rex and said do you know where i can get a new window for my rex, its an si. i have an si and have replaced one of my front windows a long time ago. i was wondering will a dx or hf crx window fit just like an si window will? she says she had a guy tell her the si ones were smaller. i thought they were the same!....anyone???
Old Jul 9, 2004 | 10:49 PM
DXDOHCVTEC's Avatar
All 88-91 should be the same, maybe someone was tryin to over charge her saying SI's were more expensive or something.
-bump if not-
Old Jul 9, 2004 | 10:55 PM
ImportsCRX's Avatar
Default Re: (DXDOHCVTEC)
my friend has a 88 CRX DX and the windows are a little bit longer than the 89-91 CRX's. He has 89-91 CRX windows in his 88 and they dont fit too well. if anyone can back this up, then go for it.
Old Jul 10, 2004 | 10:23 AM
The ZC's Avatar
No they change 88-89 and 90-91 are different.
Plus the location of where it was made is different form another location.
Exaple: You have an 89, u look nder your hood it says made in Canada.
You cann't use a window from a model made in the usa. It wont have the exact fit.
Dave
Old Jul 10, 2004 | 11:07 AM
J-ROC's Avatar
Default Re: (The ZC)
Old Jul 10, 2004 | 12:05 PM
jskspec's Avatar
Default Re: are the windows on all model crx's the same? (bluecrxsi)
The Window Glass of 88-89 CRX and 90-91 CRX are different.
88-89 CRX are smaller
90-91 CRX are Bigger
Old Jul 10, 2004 | 12:50 PM
BlueCrxNC's Avatar
Size differences are because of pillar-mounted and door-mounted seat belts. The door-mounted belts would mean the windows are a little shorter and pillar-mounted belts leave room for slightly larger windows. This is the only difference I think there is.
Old Apr 22, 2006 | 12:59 PM
SECURITY's Avatar
Default Re: are the windows on all model crx's the same? (autosonic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autosonic &raquo;</TD></TR><TR><TD CLASS="quote">The Window Glass of 88-89 CRX and 90-91 CRX are different.
Can someone verify this? I'm about to purchase some 91 CRX windows to put in my 89
Old Apr 22, 2006 | 01:01 PM
JUN.'s Avatar
Default Re: are the windows on all model crx's the same? (SECURITY)
OK, FROM 89 -91 DOORS ARE THE SAME,,,,,,,,,,,,,,,,,,,,,,, They have Seatbelts mounted on the doors, and the trim outside the door is bigger......... So the window's are Smaller than 1988 CRX's since they dont have seatbelt mounted on doors.
Old Apr 22, 2006 | 01:11 PM
MatHadder's Avatar
Default Re: are the windows on all model crx's the same? (JUN.)
actually the 89 hf has pilar mounted seatbelts too. I am pretty sure 88 hf, si, dx, and 89 hf windows are the same, and 89 dx, si, and 90-91 windows are the same.
Old Apr 22, 2006 | 01:21 PM
Reelizmpro's Avatar
Default Re: are the windows on all model crx's the same? (MatHadder)
WTF? if your car has pillar mounted seat belts then the door glass will be LARGER(88 and some 89's) Otherwise, you need the smaller door glass to compensate for the space the door mounted belts take up (most 89 and on).
Old Apr 22, 2006 | 05:08 PM
YasRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN. &raquo;</TD></TR><TR><TD CLASS="quote">OK, FROM 89 -91 DOORS ARE THE SAME,,,,,,,,,,,,,,,,,,,,,,, They have Seatbelts mounted on the doors, and the trim outside the door is bigger......... So the window's are Smaller than 1988 CRX's since they dont have seatbelt mounted on doors.</TD></TR></TABLE>
Door seatbelt models have strengthening beams inside to support the seatbelts.
Old Apr 22, 2006 | 05:16 PM
CRX Toad's Avatar
Default Re: are the windows on all model crx's the same? (Reelizmpro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatHadder &raquo;</TD></TR><TR><TD CLASS="quote"> I am pretty sure 88 hf, si, dx, and 89 hf windows are the same, and 89 dx, si, and 90-91 windows are the same.</TD></TR></TABLE>
He is correct ^ this is confirmed information too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YasRex &raquo;</TD></TR><TR><TD CLASS="quote">
Door seatbelt models have strengthening beams inside to support the seatbelts.</TD></TR></TABLE>
Okay? That has nothing to do with windows.
Old Apr 22, 2006 | 07:16 PM
B16-CRX's Avatar
how much wider are the 89-91?? I think i might have the wrong one in my car
Old Apr 23, 2006 | 05:41 AM
SECURITY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatHadder &raquo;</TD></TR><TR><TD CLASS="quote">actually the 89 hf has pilar mounted seatbelts too. I am pretty sure 88 hf, si, dx, and 89 hf windows are the same, and 89 dx, si, and 90-91 windows are the same.</TD></TR></TABLE>
Thanks man
Old Apr 23, 2006 | 06:02 AM
G0crxG0's Avatar
Default Re: (B16-CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16-CRX &raquo;</TD></TR><TR><TD CLASS="quote">how much wider are the 89-91?? I think i might have the wrong one in my car</TD></TR></TABLE>
If you had one you'd know it.
The windows on all model 88's and HF's are the same. (larger)
The windows on all other models are the same (smaller)
All that stuff about where the window was made is a bunch of BS.
The outer trim piece on the door of 88's and HF's is split. Half on the door, half against the rear window. On other models, it's all one piece on the door, so the glass is about 1-2 inches shorter.
The guy I sold my CF hood to had just been duped the day before, bout a non 88/hf window for his 88 SI, had a big gap, needless to say, he was a very uncomfortable man: A constantly open window in the rain with a CF hood stuffed INSIDE the CRX.
Old Apr 23, 2006 | 06:05 AM
G0crxG0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The ZC &raquo;</TD></TR><TR><TD CLASS="quote">No they change 88-89 and 90-91 are different.
Dave</TD></TR></TABLE>
Im sorry but thats just ridiculous.
If the windows werent the same design, they wouldn't shut/seal properly. The ONLY way it'd make a difference is if there were different doors for different places to accomodate different windows. BUT, Honda's not stupid and keeps **** the same world wide.
I'll buy any CRX window anywhere, so long as it matches my model, it will fit no problem.
roterx7
Jun 7, 2006 07:54 PM
hotimportcrx
Oct 11, 2005 03:16 PM
FitCRX
Mar 2, 2004 03:05 PM
