88-89 CRX SI Cluster in 88-89 Civic Hatchback Dx wiring help
Old Jul 9, 2004 | 07:36 PM
Slow89HB's Avatar
Default 88-89 CRX SI Cluster in 88-89 Civic Hatchback Dx wiring help
I've already searched, but I have no idea what pins to move around so that my temperature gauge works. Ive seen several wiring diagrams but I still need help deciphering it. Help please
Old Jul 9, 2004 | 07:52 PM
Slow89HB's Avatar
Default Re: 88-89 CRX SI Cluster in 88-89 Civic Hatchback Dx wiring help (Slow89HB)
https://honda-tech.com/zerothread?id=709958 Im trying to use this, but I cant figure what to use :/
Old Jul 9, 2004 | 08:01 PM
1fst4's Avatar
if its from a 88-89 crx and its going into a 88-89 hatch its just plug and play stuff no extra wiring
Old Jul 9, 2004 | 08:04 PM
Slow89HB's Avatar
Default Re: (1fst4)
Yes the crx and hatch are different, my fuel gauge dosnt work with the crx cluster, but works fine with mine.
Old Jul 10, 2004 | 11:53 AM
Slow89HB's Avatar
bump :/
Old Jul 10, 2004 | 05:10 PM
91EFHatch's Avatar
Default Re: (Slow89HB)
it should be plug n play maybe the gauge itself is no good
Old Jul 11, 2004 | 06:30 PM
Slow89HB's Avatar
bumpity bump bump
Old Jul 11, 2004 | 06:43 PM
mr. carpenter's Avatar
should be plug and play. here's the page i used to put an si cluster in my std. go to how to's and it's at the bottom of the aftermarket custom link.
http://www.4thgenerationcivic.com/
Old Jul 13, 2004 | 07:17 PM
Slow89HB's Avatar
Well can somebody just give me the large pin pin out for a 88-89 civic, and a large pin pin out for a 88-89 crx?
Old Jul 13, 2004 | 07:19 PM
http://www.ef-honda.com/main/viewtopic.php?t=1400
i think this thread has the pinouts for all.
Old Jul 13, 2004 | 07:44 PM
hatchinprogress's Avatar
Default Re: (mr. carpenter)
i think the only difference is the cluster "cover" wont fit the swap car...plug n play
Old Jul 2, 2005 | 09:24 PM
LudeJdm's Avatar
Default Re: (hatchinprogress)
i need help with this also
LudeJdm's Avatar
Default Re: (envysionHATCH)
also have the same problem....how did you solve this???
Old Jul 4, 2005 | 09:48 AM
Kryogen's Avatar
you guys all have different problems or wiring probs. I own a 88 DX HB, and I got a 89 CRX SI cluster, plug and play, no wiring just plug it and go, It should be that way for you guys too, I think yall screwed something up on it.
Old Jul 4, 2005 | 10:14 AM
EF Two.'s Avatar
Default Re: (Kryogen)
To much misinformation. No they are not plug and play! The CRX cluster and Civic clusters wiring is different. Believe me, I tried a **** load of CRX clusters in my Civic and none of them worked.... I put in a cluster from a 89 Civic si into my 89 Civic DX and guess what..it worked. So pretty much CRX=CRX CIVIC=CIVIC. They are not plug and play! I would also try to keep the years the same or 88-89 and 90-91.
Old Jul 4, 2005 | 10:23 AM
LudeJdm's Avatar
Default Re: (EF Two)
yes exactly it is different i just finished rewiring the cluster yesterday.....and you do have to move some wires around....
Old Jul 4, 2005 | 10:33 AM
VegasEFHB's Avatar
Agreed, I have been down the CRX cluster mixed with my HB body a few times, and only one thing worked. I took the Harness diagram from EF-Honda.com relating to the 90 CRX Si and rewired it for my 88 Std Hatch. Took about 5 minutes. The biggest deal was transferring the bracket and shroud to match my dash.
I highly reccomend staying Civic-Civic/CRX-CRX and within the years sub-models.
Old Jul 4, 2005 | 10:49 AM
Deetz's Avatar
Crazy Honda Guy
Holey smokes...so many posts and so much confusion!!
I have switched over many 88-89 dx to Si clusters plug and play!
During those years, there are "two" different mfg's who makde the clusters, both with different pinouts. In the Corner of the Speedo at the bottom, it will be stamped either NS or ND.
ND= Nippon Denzo
NS= Nippon Sieki (sp)
Just but the coresponding cluster to what you have in your current ride....boom, plug and play!
Old Jul 4, 2005 | 11:09 AM
HardSaltydogg's Avatar
All the wires are color coded, just remember same side is same side, you will have to extend about 3-4 wires, but it should all work out. I swapped in a 91 auto crx cluster into a 88 man hatch
Old Jul 4, 2005 | 12:59 PM
FalkenSiR's Avatar
Default Re: 88-89 CRX SI Cluster in 88-89 Civic Hatchback Dx wiring help (HardSaltydogg)
I have an 88-89 LX 4D cluster in my 88 std, works just like it should. Except the temp gauge is a little lower than it should at norm op temp. but oh well....
Zatzy
10
Jul 8, 2005 07:55 AM
1SickHb
Apr 16, 2004 10:08 AM
0554
Feb 28, 2004 08:02 PM
type_racerz
11
Feb 12, 2003 09:56 PM
xci_ed6
Nov 1, 2002 06:26 AM
