Fuel Pressure on D16Z6???
Old Nov 21, 2001 | 09:33 AM
REDBARON's Avatar
Default Fuel Pressure on D16Z6???
What should the fuel pressure be on my engine. I have an adjustable B&M FPR, and it's set to 50psi. This is my setup. 90 civic hb with 95 sohc vtec, 88-91 si ecu, injectors, and distributor. Any help is really appreciated.
Thanks.
Old Nov 21, 2001 | 09:48 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Fuel Pressure on D16Z6??? (VTECHatch)
If using the stock 88-91 ECU, 48-50 psi with the vac line off is what most are using. Be forewarned, this makes the car rich under normal driving, esp. at idle.
rasinhell
Jul 6, 2005 11:57 PM
808eg6
May 12, 2002 09:51 PM
REDBARON
Nov 21, 2001 10:15 PM
