Car wont start
Old Jul 9, 2004 | 03:40 PM
98AccordEX's Avatar
Default Car wont start
i swapped in a B16 in my 90 DX and now nothing happens. i turn the key and absolutely nothing happens except the check engine light turns on. starter doesnt turn over. fuel pump doesnt turn on. could it be my main relay? is there a way to test them? anyone have any other suggestions? the starter works. the fuel pump works. the battery has plenty of juice. all the grounds are fine. i tried 2 different ECU's (PWO and PR3). i'm not really concerned about getting it to start right away but i at least need it to do something so i can diagnose it. i would just like the fuel pump to turn on and the starter to click. then i'll go from there. but what should i do to get it to happen?
Old Jul 9, 2004 | 03:52 PM
temp's Avatar
Default Re: Car wont start (98AccordEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98AccordEX &raquo;</TD></TR><TR><TD CLASS="quote">i swapped in a B16 in my 90 DX and now nothing happens. i turn the key and absolutely nothing happens except the check engine light turns on. starter doesnt turn over. fuel pump doesnt turn on. could it be my main relay? is there a way to test them? anyone have any other suggestions? the starter works. the fuel pump works. the battery has plenty of juice. all the grounds are fine. i tried 2 different ECU's (PWO and PR3). i'm not really concerned about getting it to start right away but i at least need it to do something so i can diagnose it. i would just like the fuel pump to turn on and the starter to click. then i'll go from there. but what should i do to get it to happen?</TD></TR></TABLE>
well if the starter isnt turning on then you DO have a loose connection somewhere, double check the prong plug that goes onto the starter and see that its properly secured
Old Jul 9, 2004 | 04:10 PM
98AccordEX's Avatar
Default Re: Car wont start (temp)
i'm pretty sure its not anything that is loose. the prong is tight. i put a jumper wire from the main power to the starter to the signal wire and the starter clicked like it should. according to the voltmeter all the grounds are good. the fuel pump doesnt turn on at all. thats why i am thinking that its something more than something just not loose. its like theres no power in the car at all. would the check engine light come on if the main relay were bad?
Old Jul 9, 2004 | 04:13 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98AccordEX &raquo;</TD></TR><TR><TD CLASS="quote">i'm pretty sure its not anything that is loose. the prong is tight. i put a jumper wire from the main power to the starter to the signal wire and the starter clicked like it should. according to the voltmeter all the grounds are good. the fuel pump doesnt turn on at all. thats why i am thinking that its something more than something just not loose. its like theres no power in the car at all. would the check engine light come on if the main relay were bad?</TD></TR></TABLE>
yeah the CEL would come on, the thing that is bothering me is that the starter is not cranking at all, which means there has to be a lose wire SOMEWHERE, if the fuel pump isnt coming on that could also be due to bad grounds or the main relay
Old Jul 9, 2004 | 04:28 PM
STG3PWR's Avatar
was the car perfectly ok before swap, ie no problems; driving etc?? or did you just bought the car not running and swapped it in?
Old Jul 9, 2004 | 08:29 PM
98AccordEX's Avatar
Default Re: Car wont start (ADVANcrx)
i bought the car as a shell. it had a motor in it that ran before but it didnt run very well. i also put in a fuel cell with an MSD Inline pump because all the fuel stuff was rusted
what happens when the main relay goes bad?
Old Jul 10, 2004 | 06:10 AM
98AccordEX's Avatar
alright now the fuel pump turns on. i didnt do anything to it except unplug the main relay. the fuel pump turned on without the main relay plugged in. then i plugged it back in and it still turns on
Modified by 98AccordEX at 3:34 PM 7/10/2004
Old Jul 10, 2004 | 06:52 AM
98AccordEX's Avatar
alright well now that i've let the battery connected for about a half hour now the starter comes on. now i'm getting somewhere. fuel pump and starter working. woohoo
Old Jul 10, 2004 | 07:03 AM
MENACE's Avatar
Try a new main Relay. Sounds like your problem man.
Old Jul 10, 2004 | 12:14 PM
98AccordEX's Avatar
Default Re: Car wont start (crx480)
well i got the car to start. then it stopped. now the fuel pump doesnt turn on and theres no spark. i just checked for spark through the wires and havent broken it down any further than that yet. anyone have any advice?
Old Jul 11, 2004 | 06:50 AM
98AccordEX's Avatar
up
Old Jul 11, 2004 | 07:57 AM
bluecrxsi's Avatar
your ignition switch can cause lots of problems with fuel pump etc...... check that too. mine went and i could not start the car cause the fuel pump wouldnt stay on
Old Jul 11, 2004 | 04:28 PM
98AccordEX's Avatar
Default Re: (bluecrxsi)
alright. thanks man. i'll give that a shot
Old Jul 11, 2004 | 06:45 PM
Origin's Avatar
Default Re: (98AccordEX)
you say you have all your grounds. just making sure but do you have the ground on the thermostat down tight? i forgot about it early on in my swap and i would get fuel sometimes and other times not. the only time i would was when the ground for the thermostat would accidentally brush against the thermohousing.
Old Jul 12, 2004 | 01:58 PM
98AccordEX's Avatar
Default Re: (Origin)
i am pretty sure i have that ground. but i will double check it. thanks
lif3tak3n
Jun 24, 2014 06:00 AM
dc2LS
Mar 27, 2011 01:54 PM
jdavis94teg
May 12, 2009 09:28 AM
fryman
16
Dec 31, 2008 07:56 AM
ITR.#1446
Oct 28, 2003 11:19 AM
