Temp gauge help
Old Jul 9, 2004 | 03:29 PM
Slow89HB's Avatar
Default Temp gauge help
Ive searched, but havent found anything pertinent to my problem. After swapping in a crx si cluster into my 89 hatchback, the temperature gauge shoots up to above high, but my old cluster's thermometer works fine. Is there any way I can alter the si cluster so the temp gauge works?
Old Jul 9, 2004 | 05:41 PM
Rywire's Avatar
Default Re: Temp gauge help (Slow89HB)
Are they both 89? just swap in the temp/gas gauges into the other ones.
Old Jul 9, 2004 | 05:43 PM
crx_88_si's Avatar
Default Re: Temp gauge help (droppedcrxsi)
my 88 crx si does that too, like when i hit a bump it will bounce right up to H or above. If I smack the cluster cover it usually drops down.
Old Jul 9, 2004 | 06:28 PM
Slow89HB's Avatar
The hatch isnt an si, so the gauges wont work, I have the si cluster, but I dont know which pins to swap so taht everything works correctly.
Chucksinbong
Dec 14, 2012 08:01 PM
scott3193
Apr 8, 2012 08:43 PM
hot_rice
Jul 13, 2009 10:48 PM
Jester88Si
Dec 13, 2003 07:55 PM
