17's vs 15's...
Old Jul 9, 2004 | 03:25 PM
..::91TEG-G2::..'s Avatar
Default 17's vs 15's...
k, are there any differences in size between a set of 17's with 205-40-17 tire or a set of OEM steelies off a 91 DA with orig tire size, i think thats 195-50/60-15? (not too sure on the middle number)
i know more and less tire, more and less rim.. all that.
cuz i got 17's, and im lookin at other rims, sizes, blah blah, and the tires on my 17's are going out, and i still have some tread left on my steelies, so i was goin to swap them until i get new rims and tires. and my car's lowered 2 inches so will that bring my car lowere to the ground if i put on the 15's?
Old Jul 9, 2004 | 03:27 PM
aznballer's Avatar
it shouldnt if the tires make it the same as stock
Old Jul 9, 2004 | 05:14 PM
patmcd's Avatar
Default Re: (aznballer)
I wouldnt think so. It looks like you have the correct size on your 17's to match the diameter of the stock 15's with tires. If it does change the height it will be very little.
Old Jul 9, 2004 | 08:56 PM
Default Re: (patmcd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patmcd &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt think so. It looks like you have the correct size on your 17's to match the diameter of the stock 15's with tires. If it does change the height it will be very little. </TD></TR></TABLE>
what sizes do people run on there 15's and 16's? 205/__/15-16??
Old Jul 9, 2004 | 09:08 PM
IntegraBoy04's Avatar
Default Re: (..::91TEG-G2::..)
I think most people run 195/55/15 and 205/45/16.
Old Jul 9, 2004 | 09:55 PM
patmcd's Avatar
Default Re: (IntegraBoy04)
I have 205/45/R16 but you can also run a 205/40/R16. It sort of depends on what tire you want to run since some are only made in one size or the other.
Old Jul 10, 2004 | 04:35 AM
PHAT-INTEGRA's Avatar
Stock 15" are running 195-55-15
My 17x7.5 I'm running 215-40-17
Old Jul 10, 2004 | 06:26 AM
Chris_Bye's Avatar
Default Re: (PHAT-INTEGRA)
you could put the old wheels on, i have the same springs as you and i'm running 195-55-15's all around, it works great, you will actually be lower to the ground , if you're into that sort of thing.
Old Jul 10, 2004 | 07:03 AM
Solipsist's Avatar
I'm using 205/50/15.
Old Jul 10, 2004 | 09:00 AM
2ndgentegracer's Avatar
Default Re: (Solipsist)
I'm pretty sure stock DA steelies are 14's, I could be wrong but I'm almost positive they're 14's.
Old Jul 10, 2004 | 09:22 AM
BLacK FirE's Avatar
Default Re: (2ndgentegracer)
I'm using 205/40/16. When I get new tires I'm thinking of gettin 205/45 instead tho but we'll see.
Old Jul 10, 2004 | 11:22 AM
Default Re: (91ntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ntegra &raquo;</TD></TR><TR><TD CLASS="quote">you could put the old wheels on, i have the same springs as you and i'm running 195-55-15's all around, it works great, you will actually be lower to the ground , if you're into that sort of thing.</TD></TR></TABLE>
i am into that sorta thing, but this is the catch. i got s.techs on my ride, 2 inch drop all around.. and my car's about 3 inches, maybe 4 max, off the ground from the lowest point of the car, which suprisingly is the headshield on the cat. i can bairly put my pinky finger between the tire and fender gap... its pretty low, i dont really wanna lower it anymore.
what about getting some 16's. what would be a good tire for there? 205/ /16?
or think i should just keep the 17's
Old Jul 10, 2004 | 10:40 PM
205/45 like stated above.
Old Jul 10, 2004 | 10:47 PM
Colin's Avatar
You are correct, all oem wheels for DA integras were 14" and tire size was 195-60-14
As for your size question.... why don't you help yourself and do two things... First use a measuring tape and measure both sets, that should give you a close idea of size differences. you can also measure circumference by rolling the wheels, then caluculate diameter. Second, you can just calculate size by the size written on the side of the tire.....example, 195-60-14, calculate 60% of 19.5cm, double this number and add to the cm equivalent of 14" This gives you the diameter. But remember you will actually want to look at the radius since the difference in radius between the two sets of wheels/tire will determine how much of a height change you will see when its on the car.
Most likely the 14's will be a little smaller, plus they are larger sidewall and a bit softer sidewall, so they'll flex more under pressure. But stock wheels/tires and a 2" drop still isn't that low. Yeah, maybe a tiny bit lower than you're used to now with your 17's, but nothing dangerous, nothing you can't deal with until you get new tires, or deal with forever for that matter....
Old Jul 11, 2004 | 01:47 AM
riceball777's Avatar
Default Re: 17's vs 15's... (..::91TEG-G2::..)
stock g2 has 195/60/14
g3 has 195/55/15
the closest tire size to stock with a 16 inch rim is 205/45/16
and closest for 17's are 205/40/17
my friend just changed rims on his teg and he bought the rims with 205/40/16's and they were a good anound smaller than the stock 14 inch rim 195/60/14
Old Jul 11, 2004 | 09:04 AM
Default Re: 17's vs 15's... (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">stock g2 has 195/60/14
g3 has 195/55/15
k, thank you guys sooo much for the help. i just need to figure out what rim size i want, so many styles to choose from too.
but thanx again
Rick hybrid
Dec 9, 2007 11:35 PM
CeNCaL-DA9
Sep 4, 2007 09:10 PM
pushlatency
Oct 26, 2006 11:02 AM
661rex89si
18
Jun 13, 2006 08:15 AM
Odessa
Aug 10, 2003 12:04 AM
