need some serious help duno why its doing this...
Old Jul 9, 2004 | 03:03 PM
pearlteg's Avatar
Default need some serious help duno why its doing this...
i just installed skunk2 im and the jdm itr head. there are no leaks in the exhaust system. the vacum reads at 21hg and my spark plugs after idling for about 4 min are dry, shouldnt they have mositure. Andfor some reason my idle is at 1500. could it be fuel injectors are cloged or might need bigger ones, i duno. and i also tried adjusting the idle speed and 1300 was the best i could do. whats going on... ahh its frustrating me. can anyone help... thanks..
Old Jul 9, 2004 | 05:10 PM
warrick's Avatar
Default Re: need some serious help duno why its doing this... (pearlteg)
check your IACV, make sure the wiring is good, and that it is not clogged.
what gasket did you use?
did you let the car warm up completely?
Old Jul 9, 2004 | 08:31 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: need some serious help duno why its doing this... (warric_k)
Of course also look for a loose or disconnected vacuum line.
Do you have an erratic idle? Check out this article:
http://www.hondaswap.com/forum...29790
You can even try emailing the author of the article as I did. He was very responsive and helpful even though ti turned out not to be the IAC as I first thought.
Good luck!
Old Jul 9, 2004 | 11:25 PM
pearlteg's Avatar
Default Re: need some serious help duno why its doing this... (Gee3)
i got it down to 1300 today and i found a leak in the throttle body i found out by spraying carb cleaner and the idle when up finally i hope that the problem.
Old Jul 10, 2004 | 01:07 AM
tC_Dragon's Avatar
glad to hear you found at least one thing it could be... keep us posted. dood so whens the next fuddruckers meet?
Old Jul 10, 2004 | 01:10 AM
tC_Dragon's Avatar
glad to hear you found at least one thing it could be... keep us posted. so whens the next fuddruckers meet? lol
Old Jul 10, 2004 | 08:54 AM
pearlteg's Avatar
Default Re: need some serious help duno why its doing this... (pdcdragon)
sahiet i duno hahah did you go to the last one?
Cardinals87
Sep 21, 2016 07:24 PM
themorphious
Engine Management and Tuning
Mar 24, 2012 08:46 AM
jdmdseries
Jan 23, 2008 05:52 PM
rurkster
Nov 14, 2002 05:52 AM
