Removing paint from ITR calipers...
Old Jul 9, 2004 | 01:11 PM
REDTOPAlchemy's Avatar
Default Removing paint from ITR calipers...
I bought my R second hand and I have been meaning to remove the red paint off the OEM R calipers because I think it looks silly. The problem is I dont want to soak the caliper in paint stripper and risk possible damage to the caliper (ie. pistion seals). Any ideas??? Also, do they offer rebuild kits for our stock R calipers???
Old Jul 9, 2004 | 01:19 PM
Mugen Mike's Avatar
Default Re: Removing paint from ITR calipers... (PYXITR)
Wire brush and/or Dremel perhaps?
Yes, they do offer a rebuild kit for the ITR calipers. In my opinion, it would be easier to exchange the painted calipers for a freshly rebuilt set than to try and strip off the paint.
Old Jul 9, 2004 | 01:28 PM
Tommy_Gunns's Avatar
This is what I did, use a cloth or brush to apply the paint stripper ensuring it only comes in contact with the caliper body. Let is sit for 5-10 minutes, then use a wire brush to remove the paint. Repeat till the caliper looks like you want it to.
After you are satified with the results, drench the calipers with water (garden hose works) to remove any residue paint stripper off of your calipers.
<---also a victim of purchasing a used ITR with red calipers.
Old Jul 9, 2004 | 01:29 PM
Default Re: Removing paint from ITR calipers... (Mugen Mike)
yeah...i thought it might. Usually personal projects turn into disasters. Where can I get a set of Re-built ITR calipers?
Old Jul 9, 2004 | 01:52 PM
Dogginator's Avatar
Daisy... Daisy...
The P/Ns are 45018ss0a00 and 45019ss0a00. (You must love the JDM parts CD!) I know that these were used on the 97- Preludes. I also think that they were used on some Accords. The seal kit is P/N is 01463st7r00. It costs about $20, and you will need two of them.
Old Jul 9, 2004 | 02:01 PM
Default Re: Removing paint from ITR calipers... (Dogginator)
thank you very much!!!
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PYXITR &raquo;</TD></TR><TR><TD CLASS="quote">Where can I get a set of Re-built ITR calipers?</TD></TR></TABLE>
Dealership, Autozone, etc.
I just recently Emailed this company for a quote http://brakeco.com/
Here's what they came back with:
Front calipers $44.98 each exchange, plus $60.00 refundable deposit
Rebuild kit 10.98
Rear Calipers 84.98 plus 45.00 refundable deposit
Rear rebuild kit 9.48
Old Jul 9, 2004 | 02:15 PM
Just curious, but can anyone give me the part #'s for 00' ITR calipers, front and back?
Old Jul 9, 2004 | 05:39 PM
Edwin's Avatar
wire brush from the paint section that's all i used.
Old Jul 9, 2004 | 05:40 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PYXITR &raquo;</TD></TR><TR><TD CLASS="quote">Just curious, but can anyone give me the part #'s for 00' ITR calipers, front and back?</TD></TR></TABLE>
These are for a 2000 JDM ITR
Front calipers: 45018-SS0-A01 and 45019-SS0-A01
Rear calipers: 43018-S03-Z02 and 43019-S03-Z02
Old Jul 9, 2004 | 05:42 PM
Thank you!
Old Jul 9, 2004 | 05:44 PM
rathead's Avatar
a friend of mine used some kind of eagle one wheel cleaner.
took the paint off to nice silver metal. i think eagle one makes some kind
of heavy duty wheel cleaner.
let just say, while he was cleaning them, a little splash hit his lip,(lip on his face, not a front lip ) and made a nasty burn on his lip.
Old Jul 9, 2004 | 06:50 PM
DC2 to AP2's Avatar
Default Re: Removing paint from ITR calipers... (rathead)
i am to a victim of painted calipers. mine are gold though. if you were to get rebuilt itr calipers are they just as good?
Old Jul 9, 2004 | 07:09 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Removing paint from ITR calipers... (xdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xdriver &raquo;</TD></TR><TR><TD CLASS="quote">i am to a victim of painted calipers. mine are gold though. if you were to get rebuilt itr calipers are they just as good?</TD></TR></TABLE>
What is the deal with painted calipers? Are these just bad paint jobs? I noticed that many caliper paint jobs look chalky.
After I installed my Mugen MF8s, I had to paint mine because they had much corrosion on them. I chose Ford engine red paint for the actual calipers and gloss black for the caliper brackets. I sanded and primed the calipers before the paint application. My paint job actually looks good. Check it.
Old Jul 9, 2004 | 07:22 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Does anyone here knows the stuff that you buy off AutoZone or other auto parts store about this producut in an aerosol can that you spray on the paint and it removes it like magic? I forgot what it's called. I've seen it somewhere in H-T about thsi guy using it to remove the paint off his valve cover.
DOES ANYONE HERE KNOW WHAT I'M TALKIN ABOUT?
Old Jul 9, 2004 | 07:35 PM
Mugen Type R's Avatar
i have to agree with dogginator here, i chose to paint mine red with high temp epoxy paint because they we're rusted and i think they look great with my Mf-10's (almost same as your picture although 16' with biggeR rotors)
they came out looking smooth, i sanded them down with a steel brush mesh bit on my drill so all the rust would leave, the only way i could have gotten them to stay stock looking was to clear coat them so i figured i was gonna paint em. Like it or hate it kinda thing i guess, i wouldn't call it ricing out my R though, as compared to rust it's somewhat of an improvement
Old Jul 9, 2004 | 09:29 PM
Super_Eg6's Avatar
red may look nice but you cant beat the look of the OEM bronze calipers...mine had corrosion on them but a wire brush and heavy duty cleaner did the job...
Old Jul 9, 2004 | 10:07 PM
rcurry14's Avatar
its called aircraft remover i think.
Old Jul 10, 2004 | 05:13 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Super_Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super_Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">red may look nice but you cant beat the look of the OEM bronze calipers...mine had corrosion on them but a wire brush and heavy duty cleaner did the job...</TD></TR></TABLE>
Unfortunately for those of us in the snow belt, road salt will swiftly turn that bronze color to rust. The remaining corrosion protection lingers as white spots. Painting or powder coating is the only way to fix this.
I think a common mistake people make when painting their calipers is to paint the caliper bracket the same color as the caliper. I am not a fan of that look at all.
SOHC_me
18
Jan 31, 2007 06:17 AM
RTW DC2R
Aug 1, 2003 08:34 AM
quixonite
May 13, 2003 01:40 PM
red00gsr
Feb 2, 2002 09:00 AM
