brake problem?
Old Jul 9, 2004 | 11:19 AM
civinprogress's Avatar
Default brake problem?
When i slow down i hear squeaking noises from my front passenger side wheel well. My steering wheel also shakes.
Old Jul 9, 2004 | 11:22 AM
EL Vap133's Avatar
Default Re: brake problem? (civinprogress)
Sounds like you have warped rotors, you can try resurfacing them or getting new ones.
Old Jul 9, 2004 | 11:23 AM
Filthy Focker!'s Avatar
Squealing may have a couple of causes.
1. Dirt is stuck between your pads and rotor. or
2. You do not have alot of pad material left and the brakes are warning you.
Now for the shaking, if your steering wheel vibrates when braking and the faster you go, the more violently it shakes, then you have warped rotors.
THe best thing to do is to replace the pads and turn the rotors if you can.
Now, you may wish to go to a brake shop and have a free estimate, or
take your wheels off and have a looksee.
fs
btw, get a manual if you are not conmfortable with this.
Old Jul 11, 2004 | 09:01 AM
Default Re: brake problem? (filthy_shovel)
The steering wheel only shakes when im braking. WHen i accelerate, the car is fine. Im going to take it to the shop and have it looked at. Thanx for your help.
Old Jul 11, 2004 | 09:23 AM
vtecn8ive's Avatar
Warped rotors for the shaking
and
some brake indicators going off letting you know they are to low! (soft metal rubbing against your rotor making a squeaking noise)
arielb1
May 23, 2009 09:09 AM
james p.
13
Jun 5, 2005 08:17 AM
zseeanz
Mar 24, 2004 02:41 PM
speedehatch
Dec 3, 2003 11:57 AM
bren1339
16
Oct 15, 2003 01:08 PM
