will a 4spd d-series vss work in a y1?
just like the topic says, i really need a vss and no longer have my si tranny, but I can get ahold of a 4spd vss but i'm not sure if its the same.
why would sohc and dohc have anything to do with the speed sensor..
everyone else on here says use the d-series vss in the b-series trannys.. so, anyone on here know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTeC4TheChildren »</TD></TR><TR><TD CLASS="quote">sohc vss will not work with Dohc Tranny
Would you like to back that up with some fact, experience, or some sort of reasoning?
you can use a 5speed d vss in a y1 tranny i did worked fine it was metal dont know about the 4 speed one but i would guess that it would not work cause of the gearing. m2c
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTeC4TheChildren »</TD></TR><TR><TD CLASS="quote">sohc vss will not work with Dohc Tranny</TD></TR></TABLE>
Seeing I'm running a d-series unit in my Y1 I don't see why it wouldn't work.
anyone know about the 4spd gear? its either the 4spd gear or i'll have to wait till the mechanic with my old tranny gets the vss out (its stuck).
A D NOH
Jul 22, 2003 10:54 AM
