constant white smoke
i had a complete a6 motor but decided to do a mini me got a z6 head for cheap put it on and was a bad head so put my a6 head back and when i started it up constant smoke, let it reach normal temp but didnt stop rev it and even more smoke comes out what could it be????
Jon
Jon
Back up a bit...
Correct me if i am wrong:
1. Your engine was fine and you replaced the head.
2. THen you found out the head was bad so
3. You put your old head on it.
Correct?????
If that is the case, answer these questions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel »</TD></TR><TR><TD CLASS="quote">Did you use a new head gasket?
Did you use the correct head gasket?
How were the mating surfaces?
fs</TD></TR></TABLE>
fs
Correct?????
fs
Maybe that is it my friend. Reusing head gaskets is not a good idea. I suggest you go out and buy a new head gasket and try it out with the proper torque values and see.
Remember, coat those head bolts with antiseize or oil so they don't bind...
fs
fs
shm91
32
Feb 26, 2014 07:31 PM
ill try and hope it stops smoking like a train
