will bfg g force drag 215/50/15 fit on si wheels
Old Jul 8, 2004 | 09:23 PM
Ek00fbp's Avatar
Default will bfg g force drag 215/50/15 fit on si wheels
I have seen a stock type R wheel fit a 225 50 15 bfg drag radial but can I fit a 215 on my si wheels? they're 15x6.5
Old Jul 8, 2004 | 09:44 PM
JonGP4's Avatar
Default Re: will bfg g force drag 215/50/15 fit on si wheels (Ek00fbp)
yeah it'll be hanging over alittle but 215's should fit..
Old Jul 8, 2004 | 09:50 PM
Ek00fbp's Avatar
Default Re: will bfg g force drag 215/50/15 fit on si wheels (JonGP4)
what about 225's I just read a post about someone having 225's on his but I don't know how true it is. this is forced induction related because none of us can get traction
Old Jul 8, 2004 | 09:54 PM
beerbongskickass's Avatar
I have 205's on my HX wheels and they are 5.5 inches wide. I am guessing you won't have a problem running 225 on 6.5 inch wheels.
Old Jul 9, 2004 | 04:05 AM
Rory Breaker's Avatar
Are Si wheels 6.5 or 6"?
Either way, Ive seen guys run the 225's on stock GSR wheels which are 6" wide, so you shouldnt have any issues. Possibly some rubbing at full lock depending on your suspension I would say.
Old Jul 9, 2004 | 04:10 AM
PM-Performance's Avatar
stock type R wheels are 15x6 and i have 225's on them . so that should answer your question
Old Jul 12, 2004 | 11:03 PM
AMS MIKE's Avatar
Default Re: will bfg g force drag 215/50/15 fit on si wheels (itr206)
I have seen both 215/50/15 AND 225/50/15 on SI wheels 15x6
Check out the DOT approved slicks for real traction on the streets and keeping it legal I have not tried them but seen them work quite well!
OR BFG drag radials if they even hook up! I wish I could use the BFG's, they are cheaper than DOT street slicks. oh well
Old Jul 12, 2004 | 11:30 PM
slowsi00's Avatar
225's here
raise the car a little and they will pit purfect
Old Jul 25, 2004 | 07:22 PM
96dc2's Avatar
Si wheels, as well as ITR wheels, are 6" wide.
Old Jul 25, 2004 | 07:33 PM
dunkd's Avatar
they will fit fine....
Old Jul 25, 2004 | 07:43 PM
cinq's Avatar
they will fit fine, but will ride funny..i had them on my si's wheels...and didn't like it much...too unstable for me..going down the track over 100mph was scary...car goes side to side.....better get 205/50/15 instead...or get wider wheels.
Old Jul 26, 2004 | 07:17 AM
Muckman's Avatar
Moderator in Chief
would a 7" wide wheel be the ideal width for a 225 tire? or would it be 7.5"?
DeLucia
Feb 17, 2011 11:43 AM
JDM00SI
May 29, 2006 10:30 AM
Xymox007
May 24, 2004 08:50 AM
roydogg
Dec 5, 2003 08:59 PM
Todd00
Nov 26, 2001 09:36 PM
