DA: H&R RACE springs and KYB GR-2
Old Jul 8, 2004 | 07:06 PM
Robstunner4's Avatar
Default DA: H&R RACE springs and KYB GR-2
ok, so i just bought that set-up , all around KYB GR-2 and H&R race to go with it. i have done some reasearch, and the results are 50/50 and dont really match to this setup. i was wondering what you guys think of this set-up. i am just doing daily driving also (safe driver). some people have told me personally that it will hold up, others are against this set-up. does anyone have this set-up?? TIA
Old Jul 8, 2004 | 07:29 PM
timmy8151's Avatar
Default Re: DA: H&R RACE springs and KYB GR-2 (Robstunner22)
The GR2's are basically a stock replacement. The H&R Race springs may be too much for the GR2's over a long period. With H&R race springs I would of went with Konis.
Old Jul 8, 2004 | 07:47 PM
obd2gsr's Avatar
it will hold up fine for a while, just not for THAT long.
the kyb gr2's match up excellent with the H&R OE replacement springs, though
Old Jul 9, 2004 | 01:50 PM
Default Re: DA: H&R RACE springs and KYB GR-2 (obd2gsr)
how long is a "while" would tokico illumnias or KYB AGX work if i got those. if "a while" proofs long enough, i will uses them, then get better. also, if i were to sell the GR-2s and buy a better pair, will my stock shocks handle the drop for like a week or not?
thanks allot guys, you are a great help
Old Jul 9, 2004 | 06:53 PM
obd2gsr's Avatar
a while depends on a bunch of things, but i'd say the worst 6 months, and the best about 2 years? really a random guess, because i don't know.
your stock shocks will handle the drop for a week. just don't go over too many bouncy surfaces.
Old Jul 9, 2004 | 07:25 PM
mr.beeks's Avatar
correct me if im wrong but
the HR race drop like 2.0 in the front
and 2.25 in the rear
and the kyb have a longer piston travel therefore
no good right....
Old Jul 9, 2004 | 07:53 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Yoink! This is what I said from the same thread Robstunner made on G2IC:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDude &raquo;</TD></TR><TR><TD CLASS="quote">Honestly, H&R race is too low of a drop for KYB GR2s. Those shocks are only supposed to be used with the stock springs, as a better OEM replacement. Even if you had H&R sports (taller springs) or KYB's best shock, the AGX, I would still be concerned about your setup.
You're dropping your car. If it's not done right, it will never be done because **** will keep breaking on yo ***.
I believe you have 2 options at this point if you want it done right.
1.) Install the GR2s with the stock springs, keep the H&Rs , and finish collecting parts to drop your car. Do it right; done. Your car would be fixed for the moment, and that would give you time to buy a camber kit (believe me, you'll need one for H&R race), bushings, balljoints, tie rods, etc. O, and most importantly, new shocks. H&R race needs a shock that can take 2.5-3" drop. Koni Yellows are expensive, but they will work very well with H&R race. They're not even comparable to KYB AGXs, let alone GR2s.
2.)Sell shocks and springs. Use money towards some less agressive springs and better shocks. H&R sports (or something like it, ~1.5-2" drop), and something adjustable like KYB AGX. Now I know it wouldn't be as low, and you'd have to deal with selling the parts, but in the end I think you'd be happier with this kind of setup. Having a car dumped to the ground looks good, but if it's not done right, your car will bounce all over the place, throwing your coolness right out the window.
Dropping a car is not as easy as just replacing the springs and shocks. Get a Helms manual, and see what all needs to be replaced when doing the suspension. I've been collecting parts for about 2 months, and I'm still not done. Good luck, man.</TD></TR></TABLE>
Old Jul 9, 2004 | 08:18 PM
Default Re: (MugenDude)
damn, you got me. i understand and value your post. i also wanted to get the thoughts and ideas of people other than the people on G2IC.
Old Jul 9, 2004 | 10:01 PM
patmcd's Avatar
Default Re: (Robstunner22)
IMO the gr2's will not stand up very well with the H&R race. The gr2 is essentially designed to be a stock replacement, not an upgrade. The spring rate is probably towards the upper limit of the gr2 (from what i remember the spring rates to be). But Id think the more concerning factor is the drop from the H&R race. Thats a lot lower than stock and going to be hard on a shock designed for stock replacement.
IgnitionZ055
Suspension & Brakes
Sep 21, 2008 12:53 AM
fiebru1119
Mar 26, 2006 02:48 PM
ekcivic9
Suspension & Brakes
Dec 21, 2005 09:49 AM
00siALLmotor
Aug 26, 2004 06:57 PM
Ricey McRicerton
23
Aug 6, 2003 02:54 PM
