Y1 Tranny
Old Jul 8, 2004 | 05:48 PM
kaoss_11's Avatar
B A N N E D
Default Y1 Tranny
I am trying to find out if my tranny has lsd. I did a search and could not find any thing.
Old Jul 8, 2004 | 05:49 PM
EL Vap133's Avatar
Default Re: Y1 Tranny (kaoss_11)
Is it currently on or off the car?
Old Jul 8, 2004 | 05:50 PM
kaoss_11's Avatar
B A N N E D
Put it back on today
Old Jul 8, 2004 | 05:52 PM
EL Vap133's Avatar
Default Re: (kaoss_11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 &raquo;</TD></TR><TR><TD CLASS="quote">Put it back on today</TD></TR></TABLE>
Damn, it would have been easier to tell with it out. I forgot how to tell if it has LSD with the tranny on that's why. I am sure someone knows on here, it just hasn't hit me.
Old Jul 8, 2004 | 05:54 PM
kaoss_11's Avatar
B A N N E D
Default Re: (EL Vap133)
I never knew how to check to this so as we were putting it on, on the top it had lsd stamped on it but i didnt want to jump to conclusions
Old Jul 8, 2004 | 05:56 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 &raquo;</TD></TR><TR><TD CLASS="quote">I never knew how to check to this so as we were putting it on, on the top it had lsd stamped on it but i didnt want to jump to conclusions </TD></TR></TABLE>
Unless it was removed, then it should be LSD, mine had the same thing. Looks like someone got a punch and stamped LSD on it right?
Old Jul 8, 2004 | 05:58 PM
kaoss_11's Avatar
B A N N E D
Yeah exactlly right.
Old Jul 8, 2004 | 06:08 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
Damn, it would have been easier to tell with it out. I forgot how to tell if it has LSD with the tranny on that's why. I am sure someone knows on here, it just hasn't hit me. </TD></TR></TABLE>
If you remove the axles and can see straight through the tranny it has LSD. If there is a big bar in between, that means no LSD. You may want another opinion to back this one up cause I am only 90% sure.
Old Jul 8, 2004 | 06:20 PM
kaoss_11's Avatar
B A N N E D
I do remember him saying something like that. I did more searching and found out that since it is stamped with lsd on the top then its lsd.
Old Jul 8, 2004 | 06:21 PM
kaoss_11's Avatar
B A N N E D
Does factory lsd make that much more of a difference?
Old Jul 8, 2004 | 07:22 PM
EL Vap133's Avatar
Default Re: (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
If you remove the axles and can see straight through the tranny it has LSD. If there is a big bar in between, that means no LSD. You may want another opinion to back this one up cause I am only 90% sure. </TD></TR></TABLE>
Well yeah, I knew that way but I believe there is another easier way to check without removing axles.
Old Jul 8, 2004 | 08:52 PM
Mr_CRX's Avatar
Well yeah, I knew that way but I believe there is another easier way to check without removing axles.</TD></TR></TABLE>
I thought that if you have the front wheels jacked up off the ground and you spin one wheel with your hand, the other tire would spin the opposite direction if you dont have LSD. They would spin the same direction if you DID have LSD. I could be wrong but for some reason that's what I remember hearing.
If it was me I'd just go do a fat burnout and count the stripe(s) on the pavement
Old Jul 8, 2004 | 09:05 PM
EL Vap133's Avatar
Default Re: (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">
I thought that if you have the front wheels jacked up off the ground and you spin one wheel with your hand, the other tire would spin the opposite direction if you dont have LSD. They would spin the same direction if you DID have LSD. I could be wrong but for some reason that's what I remember hearing.</TD></TR></TABLE>
I believe that is what I heard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">If it was me I'd just go do a fat burnout and count the stripe(s) on the pavement </TD></TR></TABLE>
Funny thign is that my friend took off and left 2 stripes on the ground once on his non-LSD tranny.
Old Jul 8, 2004 | 09:30 PM
Mr_CRX's Avatar
Yeah, there's always that chance.. I'd just do the wheel spin test and see which way the other wheel spins if you dont wanna pop the axles out to look through the diff.
Old Jul 8, 2004 | 09:32 PM
wtsexton's Avatar
Old Jul 8, 2004 | 11:04 PM
Nerologic's Avatar
Default Re: Y1 Tranny (wtsexton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtsexton &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
id seen some like with that lsd stamp, but i have also seen some that have the lsd stamp in black letters (kinda like the ITR's/CTR's) and had LSD
Old Jul 9, 2004 | 09:28 AM
tommyL's Avatar
Default Re: Y1 Tranny (Nerologic)
mine has the black letters "LSD" on it... jdm ys1 w/factory lsd
in case you get a chance to pull your axles, it should look like this
Old Jul 9, 2004 | 09:37 AM
EL Vap133's Avatar
That's the stamp I had on my old Y1.
Old Jul 9, 2004 | 07:44 PM
kaoss_11's Avatar
B A N N E D
Default Re: Y1 Tranny (EL Vap133)
Thats the exact stamp I have.
d16z6_b_pirate_13
Dec 13, 2007 11:16 AM
crxpwr1
10
Jun 22, 2006 11:12 AM
pr1mo_13
Dec 22, 2005 06:54 PM
litterbox
24
Apr 4, 2005 03:49 PM
DelSolKid
Dec 2, 2004 06:29 PM
