whats this shit connected too?
Old Jul 8, 2004 | 04:50 PM
trooper0641's Avatar
Default whats this **** connected too?
im having a leak somewhere around the middle to the left of my engine bay. its a high screeching sound...as the idle bounces back and forth between 1,000-2,000 rpm...when i turn off the car...the screeching fades away and dies with it. Sound fimuliar?
Old Jul 8, 2004 | 04:53 PM
IS3Fifty's Avatar
Default Re: whats this **** connected too? (trooper0641)
its a vacuum line. If Im thinking correctly it would plug into the intake itself.
Old Jul 8, 2004 | 04:56 PM
Default Re: whats this **** connected too? (TODAeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 &raquo;</TD></TR><TR><TD CLASS="quote">its a vacuum line. If Im thinking correctly it would plug into the intake itself.</TD></TR></TABLE>
lol no i mean its connected to whatevers on the other side of that hose...its a big square black **** that looks like a intake box. the connector of this thing is turnable...is it suppose to be? maybe its cracked and leaking from there? cus all i hear is something SCREECHING like *** and its coming from the middle of my engine bay.
Old Jul 8, 2004 | 04:58 PM
IS3Fifty's Avatar
ohhhhh thats your return line your talking about then. You disgard that when you install an aftermarket intake. it will plug into the box itself and then into the block below the throttle body.
that help?
Old Jul 8, 2004 | 05:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 &raquo;</TD></TR><TR><TD CLASS="quote">ohhhhh thats your return line your talking about then. You disgard that when you install an aftermarket intake. it will plug into the box itself and then into the block below the throttle body.
that help?</TD></TR></TABLE>
yes helped a little...thanks whats the black box called?
Old Jul 8, 2004 | 05:28 PM
hatchdrvr's Avatar
That should go to the EGR valve, but I've never seen one on a Honda that was a "big black box". Do you have any better pics of the "black squary ****" in question? I'm thinking possibly the IAB(intake air bypass) solenoid and/or vacuum tank.
Old Jul 8, 2004 | 10:04 PM
Default Re: whats this **** connected too? (hatchdrvr)
egr valve eh...i dont know its not big...its just a small black box with 2 nipples..and 1 of the nipple is broken! i just tried to seal the broken nipple with some sealant...and still it leaks! why?
Old Jul 8, 2004 | 11:35 PM
err valve?
Old Jul 8, 2004 | 11:36 PM
whats this **** called!
Old Jul 9, 2004 | 12:11 AM
racin-type's Avatar
omg u guys are funny
that hose connects to the EGR valve
Old Jul 9, 2004 | 12:46 AM
stockegsix's Avatar
thats connects to a pcv valve, then the pcv valve connects to that small black box behind the block.
Old Jul 9, 2004 | 12:48 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: whats this **** connected too? (stockegsix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockegsix &raquo;</TD></TR><TR><TD CLASS="quote">thats connects to a pvc valve, then the pvc valve connects to that small black box behind the block.</TD></TR></TABLE>
wow, 7 replies to get the right answer. Positive Crankcase Ventilation Valve. And yes, hooks up to your "breather box" on the block
Old Jul 9, 2004 | 12:53 AM
stockegsix's Avatar
Default Re: whats this **** connected too? (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">wow, 7 replies to get the right answer. Positive Crankcase Ventilation Valve. And yes, hooks up to your "breather box" on the block</TD></TR></TABLE>
yay!!! i got it right
Old Jul 9, 2004 | 04:35 AM
DaiJekBok's Avatar
The hose connecting to your PCV valve might be kinked. When I installed a Skunk2 intake manifold on my car, I used a piece of Autozone hose to connect the PCV with and it developed a kink and caused a stupid screeching noise and an idle fluctuation (although not as bad as you describe). Rigged a new hose from some OE Honda hose bits and all is well.
Old Jul 9, 2004 | 06:34 AM
hatchdrvr's Avatar
I meant to say PCV, I just kept thinking EGR for whatever reason. Oh well...hammer to me.
Old Jul 9, 2004 | 08:06 AM
senpai's Avatar
Default .
What fpr are you using?
Old Jul 9, 2004 | 08:56 AM
khoalie's Avatar
Default Re: (racin-type)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racin-type &raquo;</TD></TR><TR><TD CLASS="quote">omg u guys are funny
that hose connects to the EGR valve </TD></TR></TABLE>
omg you are misinformed!
civics dont have egr
Old Jul 9, 2004 | 09:00 AM
Marauder's Avatar
Default Re: (khoalie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khoalie &raquo;</TD></TR><TR><TD CLASS="quote">civics dont have egr</TD></TR></TABLE>
WRONG! The HX has EGR. (D16Y5)
Old Jul 9, 2004 | 09:06 AM
NineTwoSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">egr valve eh...i dont know its not big...its just a small black box with 2 nipples..and 1 of the nipple is broken! i just tried to seal the broken nipple with some sealant...and still it leaks! why? </TD></TR></TABLE>
because it's broken...
Old Jul 9, 2004 | 10:51 AM
Default Re: whats this **** connected too? (DaiJekBok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaiJekBok &raquo;</TD></TR><TR><TD CLASS="quote">The hose connecting to your PCV valve might be kinked. When I installed a Skunk2 intake manifold on my car, I used a piece of Autozone hose to connect the PCV with and it developed a kink and caused a stupid screeching noise and an idle fluctuation (although not as bad as you describe). Rigged a new hose from some OE Honda hose bits and all is well.</TD></TR></TABLE>
cool thanks a lot...because i AM using a fucken autozone "medium" size hose to fit into both the pcv and the breather box "although i had to force that **** in" i thought it would work but it just screeched. Well off to honda i go...get a new breather box and the other ***** to make it right. we'll see...
Old Jul 10, 2004 | 08:05 AM
khoalie's Avatar
Default Re: (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">
WRONG! The HX has EGR. (D16Y5)</TD></TR></TABLE>
dammit! well, just when does the hx count?
Old Jul 10, 2004 | 08:12 AM
TypeRmynizzoL's Avatar
get a new lil black box w nipples that are not broken
Old Jul 10, 2004 | 09:10 AM
non's Avatar
non
cool thanks a lot...because i AM using a fucken autozone "medium" size hose to fit into both the pcv and the breather box "although i had to force that **** in" i thought it would work but it just screeched. Well off to honda i go...get a new breather box and the other ***** to make it right. we'll see...</TD></TR></TABLE>
before you get raped Z10 makes this for the bseries breather box they may also make one for the d
http://www.z10eng.com
Old Jul 10, 2004 | 09:38 AM
xerox445's Avatar
Default Re: whats this **** connected too? (eg2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg2R &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.z10eng.com</TD></TR></TABLE>
Mabey its just me, but isint that a cam seal in the picture??? i think
Old Jul 10, 2004 | 09:59 AM
non's Avatar
non
Default Re: whats this **** connected too? (xerox445)
WTF ?
do you even know what a breather box looks like ?
obviuosly if I went to the site and got that pic I would have looked at the description
2. if you took time to think about it then you would realize that could not possibly work as a cam plug
a cam plug
