HX wheels should just bolt on... right!?
I picked up a set of HX wheels, and was about to mount them, but the wheels wouldnt fit on the front axles. The inside of the wheel rubs on the caliper.. Im trying to install them on a 94 Civic ex 4-door.. is there anything else i can do other than wheel spacers??
-jj
-jj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Spoon Civic Vtech »</TD></TR><TR><TD CLASS="quote">Your car is crazy and you should make it VTECH!!! Hahahahahahah
ill make sure to do that..
</TD></TR></TABLE>ill make sure to do that..
You can grind down the rotors..I wouldn't recemmend spacers. Using them leaves only a couple threads left holding the lugs on, thus risking your rim falling off during hard turns. There was a good write up someone did a while back where he installed HX rims on a blue 99/00 SI.. try searching for that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">HX wheels are 13" and HX's come with smaller rotors and calipers. </TD></TR></TABLE>
sorry, but arnt hx wheels 14? I think VX are 13'
Here is a picture of mine. You can see the 14 kinda in the middle on the right'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kKdARIAN »</TD></TR><TR><TD CLASS="quote">
Wow, those look really good! Did you paint them or have them powdercoated?
Ben
</TD></TR></TABLE>Wow, those look really good! Did you paint them or have them powdercoated?
Ben
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neonorific20 »</TD></TR><TR><TD CLASS="quote">
Ben</TD></TR></TABLE>
Painted them
https://honda-tech.com/zerothread?id=917437
thanks!
Painted them
thanks!
sorry, but arnt hx wheels 14? I think VX are 13'</TD></TR></TABLE>
Did I get my X's mixed up??? Damn, must have XXX stuff on my mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StevenTran305 »</TD></TR><TR><TD CLASS="quote">or you can use wheel spacer. and you can use washers as a wheel spacer.</TD></TR></TABLE>
Using a washers as wheel spacers is pretty unsafe. Just sand the caliper down some. It takes 5minutes.
Guest
Posts: n/a
I wouldn't take that route.
Use a proper spacer, not washers.
just grind down the caliper a little bit. its so easy and will take 5 minutes. dont bother with spacers and all that. search for a post made by rainmanek he did a step by step post.
