pr3 obdo HOW MANY o2 Sensors?
Old Jul 8, 2004 | 01:13 PM
jondancer's Avatar
Default pr3 obdo HOW MANY o2 Sensors?
i got a 91 crx b16 obd0 setup,
running a pr3 ecu and one o2 sensor.
it hesitates a higher rpms and blows blackish smoke.
should i get my ecu chipped and eliminate the 2nd o2 sensor?
thanks
jon
Old Jul 8, 2004 | 01:21 PM
crx_88_si's Avatar
Default Re: pr3 obdo HOW MANY o2 Sensors? (jondancer)
have fun
Old Jul 9, 2004 | 03:25 AM
jondancer's Avatar
SO CAN I JUST RUN ONE O2SENSOR?
THANKS
COOL PICS/DIAGRAM
Old Jul 9, 2004 | 03:29 AM
crx_88_si's Avatar
Default Re: (jondancer)
no, you need 2, as per pics/diagram
Old Jul 9, 2004 | 05:44 AM
jondancer's Avatar
EVEN IF I GET MY ECU PROGRAMED SO ONE IS ELIMENATED?
THANKS
GUYS
Old Jul 9, 2004 | 05:55 AM
jondancer's Avatar
and if i do need two o2sensors, what vehicle
do i buy them for and are they both the same?
thanks
Old Jul 9, 2004 | 06:28 AM
ironchef25's Avatar
go to oxygensensors.com pick up a o2 sensor for under 40 bucks.
get the o2 sensor of a crx.. and your good to go..
Old Jul 9, 2004 | 06:29 AM
crx_88_si's Avatar
Default Re: (ironchef25)
just get 88-91 civic/crx o2 sensors. 2 of them.
Old Jul 9, 2004 | 06:30 AM
HT Chaplain's Avatar
Loved
Default Re: (crx_88_si)
i chipped mine to run 1. it runs great and its 1 less bung you have to add.
Old Jul 9, 2004 | 06:51 AM
jondancer's Avatar
Default Re: (LEGUTKI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LEGUTKI &raquo;</TD></TR><TR><TD CLASS="quote">i chipped mine to run 1. it runs great and its 1 less bung you have to add.</TD></TR></TABLE>
THATS WHAT I WANT TO DO, I RUNS GOOD? ANY CODES?
THANKS
Old Jul 9, 2004 | 07:13 AM
ih8sndq's Avatar
I have a 90 si with the pr3 b16. My car has both o2 sensors ran off the run before the cat. Is this bad? Don't mean to steal the post or anything.
Thanks
Old Jul 9, 2004 | 07:22 AM
crx_88_si's Avatar
Default Re: (ih8sndq)
that will work, but isn't "ideal". you may run rich or lean on 1 or 2 cyl's.
Old Jul 9, 2004 | 07:27 AM
ih8sndq's Avatar
Well what can I do to fix this?
Old Jul 9, 2004 | 07:39 AM
roadawg's Avatar
PR3 ECU can run on 1 O2 without throwing any codes. Just hook up the primary o2. Ask me how I know
Old Jul 9, 2004 | 08:04 AM
jondancer's Avatar
Default Re: (roadawg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadawg &raquo;</TD></TR><TR><TD CLASS="quote">PR3 ECU can run on 1 O2 without throwing any codes. Just hook up the primary o2. Ask me how I know </TD></TR></TABLE>
YEAH IT wont throw codes, but does it run rich?
tell us how
Old Jul 9, 2004 | 09:02 AM
crx_88_si's Avatar
ok guys.. the ECU uses 1 o2 sensor to monitor a/f mixture in 2 of the 4 cyl. that's why they are seperate.
1 o2 monitors 1 & 4 the other monitors 2 & 3.
Old Jul 9, 2004 | 10:54 AM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jondancer &raquo;</TD></TR><TR><TD CLASS="quote">
tell us how
I will find out the exact A/F when I hit the dyno, for now it seems to be running fine, I get an average of 30 MPG.
I always thought the pr3 needed two o2's to run without throwing a code, but I guess not because I only have the 1 primary o2 hooked up and it doesn't throw any codes.
Maybe the pw0 needs 2 and the pr3 needs one without throwing a code? Thats the only thing I can think of...
Old Jul 9, 2004 | 11:00 AM
crxirex's Avatar
just because your not thorwing a code, does not mean that your car is working properly. Either drill the holes and make room for the new bung, or convert to obd1. If it's ment to have 2 it needs 2. The only time it will work is when your in WOT just because its open loop.
crx_si-r
Aug 14, 2007 06:34 AM
EF8IGHT
Nov 6, 2005 09:08 PM
plastik462003
Jan 3, 2005 02:46 PM
filetofit
Feb 16, 2003 01:41 PM
