aftermarket headbolts needed for all motor?
Old Nov 20, 2001 | 09:45 PM
infinkc's Avatar
Default aftermarket headbolts needed for all motor?
do i need to get aftermarket headbolts for a NA buildup? going to be running alittle over 11-1 comp. and with a full jun head package. thanks!
Old Nov 21, 2001 | 12:09 AM
AJ PwR's Avatar
Default Re: aftermarket headbolts needed for all motor? (infinkc)
If you are running around 11:1 CR , the OEM head bolts are good enough but if you want to make your engine to run safer then go ARP and Spoon which they have decent prices.
Old Nov 21, 2001 | 05:16 AM
Mike K's Avatar
Default Re: aftermarket headbolts needed for all motor? (AJ PwR)
What makes the Spoon head bolt superior to the ARP, or the stock one?
Nothing has the clamping force of a stud. ARP's do NOT come loose.
In general, I don't think head studs are necessary for allmotor. My friend is doing ARP on his 86mm bore GSR motor.. but that's just safety factor. It's a 5mm overbore, and I would do the same on an application like that.
Mike95lude
Aug 27, 2007 07:39 PM
Turbo EH2
24
Dec 20, 2006 01:20 PM
1991hondahead
Sep 8, 2004 12:08 PM
93LudeVtec
Feb 7, 2003 02:05 AM
DLB1994
Jan 23, 2003 05:36 PM
