GSR secondary butterflies
Old Jul 8, 2004 | 11:02 AM
Turbo E's Avatar
Default GSR secondary butterflies
are they normally open or closed when the motor is off?
sorry for the n00b question.
Old Jul 8, 2004 | 11:05 AM
Charlie Moua's Avatar
Default Re: GSR secondary butterflies (Turbo E 604)
I believe they are closed until 4500rpm when ecu opens them up
Old Jul 8, 2004 | 11:13 AM
Turbo E's Avatar
so does vaccuum keep em closed?
Old Jul 8, 2004 | 11:28 AM
Default Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">so does vaccuum keep em closed?</TD></TR></TABLE>
vacume has a small part of it i think. I mean the ecu tells it when to open.
Old Jul 8, 2004 | 01:19 PM
AspectIndustries's Avatar
Default Re: (Charlie Moua)
Also, curious,... Is it beneficial to tie the Secondary Open on a boosted car? Or just leave it the way it is. -
Old Jul 8, 2004 | 01:54 PM
93TurboSi's Avatar
Default Re: (synik)
get an ls or typer manifold and lose te secondaries.
but if i had to gues on a turbo just leaving them open might be better but its just a guess
Old Jul 8, 2004 | 02:41 PM
Turbo E's Avatar
Default Re: (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">Also, curious,... Is it beneficial to tie the Secondary Open on a boosted car? Or just leave it the way it is. - </TD></TR></TABLE>
I zipted mine open (i'm assuming) and gained .5 sec in the 1/4. I **** you not.
i had run 14 flat all day. a friend suggested i ziptie the 2ndaries open. 10¢ later 13.5 consistant.
Old Jul 8, 2004 | 02:44 PM
B18C1CYA's Avatar
the butterflys are open when the motors off but when you start it they shut from the engines vacum, and btw the gsr manifold is the only one that will fit the gsr unless you get an aftermarket one.
Old Jul 8, 2004 | 08:20 PM
I will be sure to test that out
when i install my kit.
I'll also do a dyno test of the skunk2 IM vs GSR with butterlies vs GSR with ziptie open...
it should be interesting which will have more power topend as well as under the powerline.
Old Jul 9, 2004 | 11:30 AM
Yea, I will definately try this at the track. Seeing if I got any gains.
Anyone else got any inputs on this?
Old Jul 9, 2004 | 12:30 PM
Chillinit's Avatar
Default Re: (synik)
tie zipping them open will cause u to lose some torque on the low end but make it up at the top!
Old Jul 9, 2004 | 12:38 PM
Turbo E's Avatar
Default Re: (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">tie zipping them open will cause u to lose some torque on the low end but make it up at the top!</TD></TR></TABLE>
lose something i never had
Old Jul 9, 2004 | 01:02 PM
lose something i never had </TD></TR></TABLE>
I second that. Any more infos?
Old Jul 9, 2004 | 01:08 PM
No-Gi's Avatar
Default Re: (synik)
butterflies do not open till about 5800. (est)
Old Jul 9, 2004 | 01:22 PM
4g4drb17's Avatar
Default Re: (3_South)
if you take the vacuum hose off the butter flies will stay open all the time, you dont have to worry about the zip ties
Old Jul 9, 2004 | 01:35 PM
espanol's Avatar
Default Re: GSR secondary butterflies (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93TurboSi &raquo;</TD></TR><TR><TD CLASS="quote">get an ls or typer manifold and lose te secondaries.
but if i had to gues on a turbo just leaving them open might be better but its just a guess</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote"> and btw the gsr manifold is the only one that will fit the gsr unless you get an aftermarket one.</TD></TR></TABLE>
what do you expect, he drives a single cam.
Old Jul 9, 2004 | 02:13 PM
Default Re: GSR secondary butterflies (espanol)
lol.
ANYONE MUST KNOW SOMETHING ABOUT THIS!!
Old Jul 9, 2004 | 02:27 PM
boosted_dc2's Avatar
Default Re: GSR secondary butterflies (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">lol.
ANYONE MUST KNOW SOMETHING ABOUT THIS!! </TD></TR></TABLE>
what do you want to know. they open at 5800 and there there to increase low to mid end torque. if you want them opened all the time pull the vacum line of and plug it, they will be open at all times. and as far as increasing track times, ive heard both ways. however i dont see how it could increase times, when your reducing torque
Landon
Old Jul 9, 2004 | 02:40 PM
Turbo E's Avatar
Default Re: GSR secondary butterflies (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
..and as far as increasing track times, ive heard both ways. however i dont see how it could increase times, when your reducing torque
Landon</TD></TR></TABLE>
i dont get it either, but all i know is i went .5 sec faster. I know i didnt suddenly become a better driver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4drb17 &raquo;</TD></TR><TR><TD CLASS="quote">if you take the vacuum hose off the butter flies will stay open all the time, you dont have to worry about the zip ties
cool. ill try that.
Old Jul 9, 2004 | 03:00 PM
Torque will be loss... But would the boost effect anything? Opening up always, which increase more incoming low end air flow? As long the Turbo spools in enough, then torque loss will be ok? Since boosting, burn tires like no other. Qhy not limit down torque and grow high end power
But yea, I will try this at the track tonight, to see how different it pulls. (dragstrip)
Old Jul 9, 2004 | 05:48 PM
B18Flip's Avatar
i had run 14 flat all day. a friend suggested i ziptie the 2ndaries open. 10¢ later 13.5 consistant. </TD></TR></TABLE>
jeeze that's pretty damn good...i'll have to try keeping mine open
94turboeg
Aug 22, 2007 03:19 AM
ef9king
Feb 22, 2006 02:35 PM
alexturbo
Sep 6, 2005 08:19 PM
boostjunkie757
Oct 9, 2004 09:55 AM
Turbo92cx
Dec 3, 2003 08:49 PM
