stange problem: strange noise when turning a corning, or when taking off from a complete stop
Old Jul 8, 2004 | 10:20 AM
ScorpioX's Avatar
Default stange problem: strange noise when turning a corning, or when taking off from a complete stop
Hello,
Iv been trying to fix this noise for a while... and I got no clue ne more on what to change...strange noise when turning a corning, or when taking off from a complete stop. its like a "TAK" like something cracking when the car is under stress...
ball joints, driveshafts, suspension, tirods, bushings, ball joints.. i have replaced all..all are new.. im thinking it might be the cross member since the chassis has over 400 000KM... anybody had this problem? or could give me a hint what it could be?
thanks in advance.
Old Jul 8, 2004 | 11:26 AM
2lua's Avatar
Default Re: stange problem: strange noise when turning a corning, or when taking off from a complete stop (S
what about wheel bearings?
Old Jul 8, 2004 | 11:29 AM
ScorpioX's Avatar
was also changed...
i did a 5 bolt conversion thinking the noise would go away...
but the same noise persists.. with the old 4 bolts and the new 5 bolts... so its not the bearings.... it sounds like a TACK, like as if a major part is a bit loose and it cracks on high pressure.. im lost...
Old Jul 17, 2005 | 07:31 PM
JDMAN's Avatar
did you check your engine mounts?
Old Jul 17, 2005 | 08:29 PM
sicky's Avatar
grammer nawzi
Definitely sounds like a mount problem. Check the mount on the backside of the motor.
LSVTEC 91 Civic
18
Jul 25, 2005 09:34 AM
BigJohn
Jun 25, 2005 07:24 AM
Mike banX
Suspension & Brakes
May 17, 2005 04:37 AM
RSVTECDC4
Mar 17, 2004 08:19 AM
btr24evr
Feb 3, 2003 07:51 AM
