hood will not pop???
Old Jul 8, 2004 | 09:55 AM
URA91hatch's Avatar
Default hood will not pop???
my hood on my 91 dx will not pop when i puul the latch.it makes the pop noise but i cannot get the hood to come up.If anyone knows how to fix this please let me know.Thanks
Old Jul 8, 2004 | 10:07 AM
Jester88Si's Avatar
I don't know how to fix it but i know how to get around it.... Push the hood down after you hear that pop and try again it'll eventually work it does for me
Old Jul 8, 2004 | 10:11 AM
URA91hatch's Avatar
thanks
Old Jul 8, 2004 | 10:13 AM
EL Vap133's Avatar
Default Re: (Jester88Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jester88Si &raquo;</TD></TR><TR><TD CLASS="quote">I don't know how to fix it but i know how to get around it.... Push the hood down after you hear that pop and try again it'll eventually work it does for me </TD></TR></TABLE>
Old Jul 8, 2004 | 10:20 AM
lYellowDragonl's Avatar
Default Re: hood will not pop??? (URA91hatch)
i have the same problem with my crx hood which is fiberglass what i do to open it is get a friend or a stick and make sure the latch is completly up and then hit the hood down once and then lift it it always works for me guess you should try?
Old Jul 8, 2004 | 11:33 AM
SiZ's Avatar
SiZ
Default Re: hood will not pop??? (lYellowDragonl)
On my CF hood I have to have someone at the front of the car to push down on the hood while I pull the handle otherwise it won't pop. It great for when you're trying to work on the car by yourself.
Old Jul 8, 2004 | 11:35 AM
H.A.R.T b16a1crx's Avatar
Default Re: hood will not pop??? (SiZ)
sometimes the cable falls off , maybe its hooked up if you here the pop but you could check that out...
Old Jul 8, 2004 | 12:40 PM
URA91hatch's Avatar
thanks guys
Old Jul 8, 2004 | 01:23 PM
vitrox's Avatar
i had a similar problem with mine, but mine was because the cable was stretched and would no longer pull it far enough to unlatch.. I just bought a new cable and latching assembly, was only like $40 from hondaautomotiveparts.com
Old Jul 9, 2004 | 08:13 AM
URA91hatch's Avatar
i got it opened....thanks alot for all of your help.
Old Jul 9, 2004 | 08:14 AM
EL Vap133's Avatar
Default Re: (URA91hatch)
Works all the time.
Old Jul 9, 2004 | 08:18 AM
B16CRXT's Avatar
Default Re: (EL Vap133)
Mine used to do that, but it was bc it was in a wreck previously. I just pulled the release and went to the front and lifted up on it and it would come up.
Old Jul 10, 2004 | 01:14 AM
Lucias_D's Avatar
I had the same problem as well. The most likely problem is the cable isn't being pulled far enough to move the hood latch. I had to have someone push down on my hood all the time to open it before, but with some inspection I realized that the upward force of my hood was greater than the force my cable exerted. The popping noise could be from and slight curvature in the hood latch (not fully releasing).
Vitrox, went the more expensive route fixing this problem. An easy fix is to: 1.) Remove you hood release line from your latch assembly. Pull down on the cable where it enters the latch assembly, then pull the ball end of the cable through the small outlet slot. 2.) Next you need to find a locking washer that won't fit over the ball at the end of the cable. 3.) bend the washer with a pair of pliers or something so it fits on the cable line. 4.) Once on the line acquire a channel lock®, vise grip® or something that has a lot of clamping power to bend the washer so it won't come off the line (This will depend on how thick the washer is. Mine was hard as hell to bend). 5.) ENJOY!
You might have to add another washer but if you hear it pop right now it means it's close to releasing so you probably won't have to. Didn't cost me anything to fix and installed in about &lt;5 minutes!
Old Jul 10, 2004 | 11:11 AM
J-ROC's Avatar
Default Re: hood will not pop??? (Lucias_D)
Take a sledgehammer and hit the hood several times until it opens.
Old Jul 10, 2004 | 11:30 AM
91_civicsi's Avatar
Default Re: hood will not pop??? (J-ROC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-ROC &raquo;</TD></TR><TR><TD CLASS="quote">Take a sledgehammer and hit the hood several times until it opens. </TD></TR></TABLE>
hahahhahahah i almost spit my drink out when reading this :0
lmfao
no what you really wanna do is, push the pin that where the spring is, you'll have to look at it, but there is a latch/pin thing by the spring, you'll want to push that down and then close your hood, you will have to do it everytime you pop the hood though until you get a new hood latch
c0nspire
13
Aug 8, 2006 11:18 PM
chunkybs
Jun 17, 2006 07:15 AM
AutoXer
16
Jun 11, 2006 11:39 PM
Soon_2b_evil
Mar 24, 2004 03:20 PM
