Honda S2000 Honda S2000
Clicking noise from rear????????
Old Jul 8, 2004 | 09:24 AM
Project SSAP1's Avatar
Default Clicking noise from rear????????
ok this thing is really annoying the hell out of me....i hear a clicking noise from my car when first moving...ive been noticing it more as time goes on...anybody know what the hell this is?? I hope its not my rear diff going
Old Jul 8, 2004 | 10:03 AM
9kFever's Avatar
Default Re: Clicking noise from rear???????? (Project SSAP1)
will it click if you disengage the clutch?
Old Jul 8, 2004 | 12:02 PM
RFever's Avatar
It might be because the rear spline nuts need to be lubed and retorqued. There is a TSB out for the revised torque spec. It's 220 ft-lbs. I found this out on S2ki.com while researching slight vibration/shaking coming from the rear of my 01 S. The thread I read this from is http://www.s2ki.com/forums/ind...&st=0. I'll try the lube before replacing the diff. Watch closely for any shakes to follow too. I think my driver's side inner CV joint is going ... Good luck and let me know what you find out.
Old Jul 8, 2004 | 02:06 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project SSAP1 &raquo;</TD></TR><TR><TD CLASS="quote">ok this thing is really annoying the hell out of me....i hear a clicking noise from my car when first moving...ive been noticing it more as time goes on...anybody know what the hell this is?? I hope its not my rear diff going </TD></TR></TABLE>
as mentioned, the spline nuts are one source for the problem, it can also be your rear brake pads seating in place when moving foward and back.
Old Jul 8, 2004 | 05:54 PM
OC 335i's Avatar
Mine recently was because of bad wheel bearings.
Old Jul 8, 2004 | 07:17 PM
steven975's Avatar
Default Re: Clicking noise from rear???????? (JMS JT)
I have the same problem. I took the car in for the 45k service and mentioned the spline nut issue. I still have the problem...of course they may not have done the work
I think it's either the clutch, the spline nuts, or a suspension part. Sometimes the inner cup on the CV joint gets divots causing clicks, too. Mine seems to be on the passenger side. the brake pad issue seems plausible. I've ruled out the diff as I can start rolling without clicks, but when i press harder it clicks.
bmoreb18c1
Jan 28, 2014 06:32 PM
Historyg
Jul 27, 2008 07:54 PM
stephen_civic98
Mar 26, 2007 05:11 PM
hdawg06
Nov 30, 2006 08:01 PM
spock_rocker
Oct 8, 2004 09:46 AM
