rear seat is stuck, need to remove
Old Jul 8, 2004 | 09:02 AM
S9i1R's Avatar
Default rear seat is stuck, need to remove
OK the lock thing is broke off the rear drivers side seat. what needs to be done in order to get the seat out of the car?
Thanks in advance for any help
Old Jul 8, 2004 | 09:06 AM
SETI20's Avatar
Default Re: rear seat is stuck, need to remove (S9i1R)
I don't get it.
Unbolt it from the floor...?
Old Jul 8, 2004 | 09:10 AM
T-Mo's Avatar
don't mind the circle on the pic. I helped someone else out there. In this pic though you can see that on the back of the seat, the part that latches the seat. Mess around with that to unlatch the seat. ** I am bad at explaining things.*** You may have to pull the carpet off the back of the seat to see it.
Old Jul 8, 2004 | 09:23 AM
S9i1R's Avatar
Default Re: (T-Mo)
OK so I should just take a screw driver and try to get it unlatched is that what ur saying? I'll go try that now I'll let you know what the outcome is thanks again
Old Jul 8, 2004 | 09:24 AM
T-Mo's Avatar
yeah thats what I meant, good luck.
Old Jul 8, 2004 | 09:44 AM
S9i1R's Avatar
Default Re: (T-Mo)
ok so I see how it works, I looked at the opposite side. it doesn't look like there's any way to get it out without breaking the little plastic latch, has anybody been able to get it out without breaking that latch.
Old Jul 8, 2004 | 09:49 AM
gac_gonejeepin's Avatar
Default Re: (S9i1R)
break it....you won't put the rear seat back in anyway
---gabriel
Old Jul 8, 2004 | 11:38 AM
S9i1R's Avatar
Default Re: (gac_gonejeepin)
OK well that is just a plastic coating on a metal latch so it will not break. this is really annoying!!
Old Jul 9, 2004 | 08:20 AM
T-Mo's Avatar
so neither seat have a release latch.
KiddVtak!
Sep 27, 2009 08:30 PM
89sicivic
Mar 9, 2007 04:57 PM
diluted
Jul 22, 2004 01:39 PM
JerryJ
Feb 2, 2003 06:33 AM
Albino Dragon
Oct 5, 2001 01:09 PM
