why wont my car turn on???
Old Jul 8, 2004 | 08:56 AM
EF9 JAMS!!!'s Avatar
Default why wont my car turn on???
alright, for the past three or four weeks i've been gone for school and before i left the clutch in my 91 hatch went out. well, today i decided to check and see what was going on with it. i knew that i had to jump start it but when my friend and i hooked up the cables, i tried it and nothing. i let it sit for like ten min or so and i could tell that the car was turning and that it had power because before i wasn't able to see any lights come on or nothing. so i would turn the key and just nothing.
i would like to know if it's a combonation of things or one thing or what??? could it be a bad alternator a bad battery. i don't think the battery is bad because i just got it a couple of months ago sooo. can some one please help me.
thanks
Old Jul 8, 2004 | 08:59 AM
EL Vap133's Avatar
Default Re: why wont my car turn on??? (hatch91JDM)
Try using another battery. When you let a car sit for a while sometimes it drains the battery.
Old Jul 8, 2004 | 09:03 AM
Filthy Focker!'s Avatar
What do you mean by "turning the key and nothing"????????????
A boost should be able to start your car unless there is something else going on. Explain a bit more.
fs
Old Jul 8, 2004 | 09:05 AM
Default Re: why wont my car turn on??? (filthy_shovel)
well i turned the key and the lights inside the car came on but the engine would not turn over or anything
Old Jul 8, 2004 | 09:11 AM
Do you hear a click sound or nothing??
fs
Old Jul 8, 2004 | 09:15 AM
the motor shake but it just barley starts to. there's some clicking but the sound is very very faint
Old Jul 8, 2004 | 09:19 AM
Ok, let's start over here.
When you turn the key, the motor turns over yet does not want to start right?
Also, how much mechanical knowledge do you have?
fs
Old Jul 8, 2004 | 09:20 AM
i know about medium. still learning though i can pick up things pretty fast though. so if you say something i should be able to understand what you are talking about.
Old Jul 8, 2004 | 09:29 AM
Ok, so you say it starts to turn, but then quits. Well, you need more juice going to the starter.
Yet you say that even with a boost you can't get it going... That's what is puzzling. DO you have an extra good battery? Or can you borrow one from a friend?
fs
Old Jul 8, 2004 | 09:31 AM
yeah i can probably do that. but after i try the borrowed one will i need to keep that one on or can i put mine back on???
Old Jul 8, 2004 | 09:32 AM
4drEF's Avatar
Keyboard Humorist
Sounds to me that the starter is just about dead.
With a jump, like he already has tried, the starter should have kicked out and spun the motor over.
Old Jul 8, 2004 | 09:33 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch91JDM &raquo;</TD></TR><TR><TD CLASS="quote">yeah i can probably do that. but after i try the borrowed one will i need to keep that one on or can i put mine back on??? </TD></TR></TABLE>
You can take the one you borrowed off, and slap the old one on the car (while it is running) and let it charge for quite a while. If the battery is still good it wil charge up.
Old Jul 8, 2004 | 09:37 AM
Default Re: why wont my car turn on??? (EL Vap133)
wont the car die if i take it off while it's running
Old Jul 8, 2004 | 09:47 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch91JDM &raquo;</TD></TR><TR><TD CLASS="quote">wont the car die if i take it off while it's running</TD></TR></TABLE>
If the alternator was dead.
Old Jul 8, 2004 | 09:52 AM
alright then, thanks a lot for the info. i'll let ya know what happens.
thanks
Old Jul 8, 2004 | 11:50 AM
Honda Virgin's Avatar
Have you tried to push start the car?
if not, try it!
if the car starts let it run for a while so the alternator can charge the battery, if that is what the problem is.
After that, turn the car off, and try to start it again. If it does not start, but has power on everything else, then I would say that your starter is going/gone bad.
I had problems with mine, but took a while to diagnos. Read my post for further help on getting yours up and running.
https://honda-tech.com/zerothread?id=870941
PLEASE NOTE: every time I said "jump" start, what I really meant was "push" start
Old Jul 9, 2004 | 01:29 PM
Default Re: why wont my car turn on??? (Honda Virgin)
i've tried to push start it and nothing so. i the started must be bad.
Old Jul 9, 2004 | 03:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch91JDM &raquo;</TD></TR><TR><TD CLASS="quote">i've tried to push start it and nothing so. </TD></TR></TABLE>
what does nothing mean?
What gear did you try it in?
Do you still have power to the lights in the interior?
NiKKa NiKKy
Jun 30, 2022 09:59 PM
Circaskaterr
Oct 13, 2009 09:45 AM
Nocturnal
10
Aug 18, 2009 12:39 AM
my ride
Jul 21, 2004 10:40 PM
b18a1
Nov 19, 2001 01:19 PM
