got the y8 into my rex
thanks to all you guys i got my y8 in and running in my rex it took a total of like 10 hours. the only question i had was i think i read that your supposed to elongate the holes on the distributor but i dont see why it works fine. i got a question has anyone had any problems with the hood hitting the motor. i have an aftermarket hood and it hits on the nipple on top of the valve cover. i was wondering if i could cut it off. another question i had was how long can i run the motor without vtec.
also if anyone knows of somewhere cheap i can get a apex vtec controller, please let me know.
thanks again for all the help he scoots even without vtec.
yah the dizzy bolts up fine.
and running without vtec is not a problem at all.
your best bet is to go obd1 and use a p28.
but if you just want the vtec to hit, vafc would be ok. ebay has some.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slocrxsi »</TD></TR><TR><TD CLASS="quote">i have an aftermarket hood and it hits on the nipple on top of the valve cover. i was wondering if i could cut it off.
Yes, my stock hood just clears that part on the valve cover. I used the other one on the front for the ground wire.
You're not hurting anything running without vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX »</TD></TR><TR><TD CLASS="quote">
You're not hurting anything running without vtec.</TD></TR></TABLE>
it will hurt you more suffering , no vtec. more than the engine
crxboy909
Dec 27, 2010 02:45 PM
Jorsher
Mar 24, 2007 03:21 PM
