Used trannie swap
Old Jul 7, 2004 | 09:12 PM
Schmitey's Avatar
Default Used trannie swap
Might be lookin for a new/used tranny due to not having a reverse. You can read about that here https://honda-tech.com/zerothread?id=915012 please give me insight on prospective problems.
Anyways my question for this post is first off do you guys know of any trustworthy place to get used trannies? I got a 96 EX 5 spd. I found a couple locally for like $275 w/1 yr. warrantee.
Also how much would it cost me total (driveshafts, mounts, and what else?) to drop a limited slip tranny into it and what cars can i steal it from. Preferably a straight bolt on if they exist.
thanks again
Old Jul 8, 2004 | 05:06 AM
Grodzman's Avatar
What you need is an H23 tranny + Quaife LSD.
Last I recall, it's direct bolt-on w/o any need for driveshafts or mounts, unless you're doing an auto to manual conversion, which it looks like you're not.
Old Jul 8, 2004 | 06:46 AM
Schmitey's Avatar
Default Re: (Grodzman)
Need some answers from all you out there.
I can grab an H23 tranny from a 92-96 Prelude Si/Se right? Gear ratios should be between and H22 and and my F22B1 right (anyone know where I can find those by the way)?
Also is the H23 a straight bolt? I can reuse the same driveshafts and mounts right?
Modified by Schmitey at 2:23 AM 7/17/2004
Old Jul 17, 2004 | 11:24 PM
Schmitey's Avatar
Default Re: (Schmitey)
bump
Old Jul 20, 2004 | 06:18 AM
Grodzman's Avatar
Yes, everything w/ H & F trannies is straight bolt-up replacement.
Old Jul 20, 2004 | 08:36 AM
Monkey Fing a Coconut's Avatar
cheapest would be m2b4 tranny (h22a lsd) for about $1000 + install, otherwise h23/f series tranny would be 2-300 + 800(very low price) for quaife/kaaz lsd + labor to open tranny and install....
DJsilkyjr
Mar 22, 2021 07:31 AM
tommygun89hb
Dec 28, 2009 04:38 PM
Kuba_Lude
Aug 19, 2007 09:44 PM
dtr83
Apr 14, 2004 06:08 PM
vtec fan
Sep 21, 2003 03:50 PM
