Just got a uk vt cluster... wiring on a 89?
Old Jul 7, 2004 | 08:39 PM
Rywire's Avatar
Default Just got a uk vt cluster... wiring on a 89?
Has anyone with a 89 used this site?
http://www.angelfire.com/ca/DrOhm/SiRcluster.html
It seems wrong, that or I cant understand the diagram for the 88-91. I guess I will just match up the wires manually.
PS, I was going to go with a itr cluster, but this is nicer in my opinion, so if anyone needs a electronic vss, let me know. Its complete.
Ryan
Old Jul 7, 2004 | 10:56 PM
Rywire's Avatar
Default Re: Just got a uk vt cluster... wiring on a 89? (droppedcrxsi)
anyone?
Old Jul 7, 2004 | 11:00 PM
xxmaxhardcorexx's Avatar
i have the same cluster in the same year crx as you i havent wired it up yet?
need 90-91 harness
Old Jul 7, 2004 | 11:01 PM
Rywire's Avatar
Default Re: Just got a uk vt cluster... wiring on a 89? (xxmaxhardcorexx)
why would you need a 90-91 harness? I dont think so
Old Jul 8, 2004 | 05:56 AM
some of the wires are in diffrent spots, it tells you so in the
URL you posted.
Old Jul 8, 2004 | 08:08 AM
Rywire's Avatar
ya, but the 89 chart seems way off. Im looking for someone who has used it...
Old Jul 8, 2004 | 08:21 AM
4drEF's Avatar
Keyboard Humorist
At worst, you could just follow the traces on the clusters and create your own schematic.
If you have instructions for the 90/91 you may try searching for the install of the GSR cluster. I believe you will find a pin-out for the 88/89 as well as 90/91 for that install. You can compare the two and figure out what needs to be modified in your situation.
Old Jul 8, 2004 | 10:53 AM
Rywire's Avatar
Default Re: Just got a uk vt cluster... wiring on a 89? (4drEF)
Thanks, ya I started to just trace my wires back to the locations, on a couple of them, it goes to weird/different spots. For example, on the edm cluster, the traces go to the fuel upper bolt, and the temp middle bolt. Then on the si cluster it will go to the fuel bottom bolt, then the temp middle bolt.
How do you read that? Thanks
PS, most are straight foward, so I should be able to figure it out.
Old Jul 9, 2004 | 04:07 PM
Rywire's Avatar
There she is...
My god, that wasent as easy as I thought it was going to be. I had to play around with the wires a lot to get them to work correctly. But I absolutely love the outcome!! Ryan
Old Jul 9, 2004 | 04:49 PM
JDM Like Whoa's Avatar
I wanna do the same exact thing.
Old Jul 9, 2004 | 10:28 PM
Rywire's Avatar
Default Re: (ImportRacr05)
Once I make sure its wired all correctly, I will hook everyone up with the CORRECT pit out. Ryan
Old Jul 10, 2004 | 12:20 AM
jdmefhondachassis's Avatar
bump
Old Jul 10, 2004 | 04:29 AM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Default Re: Just got a uk vt cluster... wiring on a 89? (jdmefhondachassis)
Hows it going with the correct wires, I got a 88 Si, with B16, and am interested in the same thing.
Old Jul 10, 2004 | 08:17 AM
Rywire's Avatar
Default Re: Just got a uk vt cluster... wiring on a 89? (Jurassic Four)
Well, I got everything working right except the lights, I couldnt see them bacause it was too sunny yeaterday (I had to check last night) I think ist a switched wire, and I think I know which one... I wired it so the "ALB" light went to the hand brake, and the "((!)(P))" light went to the seatbelt. The edm cluster is truly weird... But you can wire it however you want.
I didnt wire up the open pass/driver doors yet(dont know if I will, there anoying anyway)
When I fix the lights, ill take note of the wire color positions, and post em... I wont forget people, be patient grasshoppers.
Ryan
Old Jul 10, 2004 | 11:07 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmaxhardcorexx &raquo;</TD></TR><TR><TD CLASS="quote">some of the wires are in diffrent spots, it tells you so in the
URL you posted.</TD></TR></TABLE>
trust me.. all those god damn wires are a mess... its a bunch of ****.. they'res about 3 diff. wiring diagrams.. so i hacked them all off, and started from scratch.
all i can tell you is they all have a single color. so match them up.
Old Jul 10, 2004 | 11:40 AM
Rywire's Avatar
Default Re: Just got a uk vt cluster... wiring on a 89? (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">
WOW bro, thats a mess. I just de pinned mine, there is no mess, it looks almost stock. I think there is like 1 wire from each plug that needed to be switched to the other plug. And I fixed my lights...
This only works if the clip is up, and the wires are coming out at you.
8pin plug
blk - yel/red - grn/blk - blu/red - empty - yel/wht - yel - grn/yel
12pin plug
grn/blu - red/blu - yel/grn - blk/red - yel/red - empty - grn/orng - empty - blu/yel - blk/yel - wht/blu - blu
The red wire is for the dimmers, there is no dimmer for the edm... Just leave it unplugged. On the dimmer switch de pin the red and the black wires, and join them, this way your lights will stay at max brightness.
The 89 si hazard plug switch was different on the 89 si harness, so I will have to head out to the parts yard for this piece.
Also, the 90-91 brackets that hold the cluster in place are needed. I didnt have them either, so I am just going to pick them up at the same time as the switch.
I just cut the tops off the brackets, it works great temporarily, its that its just held in place by one bolt, not 2. So I will pick up the 90-91's eventually.
Ryan
PS, I dont have the door warning lights working, you can hook them to the hazard light, but I didnt want to wire them up.
Old Jul 18, 2004 | 06:23 PM
i tried how you set up your wiring and my tach and lights do not work.
when i put the wires together at the dimmer switch it keeps blowing the fuse
Old Jul 18, 2004 | 06:44 PM
Rywire's Avatar
Do you have a 89 si? Thats what I have.
Old Jul 18, 2004 | 06:46 PM
I Want An Si's Avatar
The easiest way to get this cluster to work is put the gauges in to your stock 90-91 cluster...its plug and play after that
Old Jul 18, 2004 | 07:27 PM
Rywire's Avatar
Default Re: Just got a uk vt cluster... wiring on a 89? (I Want An Si)
I had a 89 cluster, dosent work that way. Ryan
Old Jul 18, 2004 | 07:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">I had a 89 cluster, dosent work that way. Ryan</TD></TR></TABLE>
thats why i said 90-91
Old Jul 18, 2004 | 08:04 PM
Rywire's Avatar
I think you are missing the point... The wiring is different between the 90-91 cluster and the 88 and 89's. I have a 89 car. Get it.
Ryan
Old Jul 18, 2004 | 08:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">I think you are missing the point... The wiring is different between the 90-91 cluster and the 88 and 89's. I have a 89 car. Get it.
I think i get that point.... The whole cluster is different for an 88/89..... so if you were just to wire it up for a 90/91 and then do what i said it would work
Old Jul 18, 2004 | 08:24 PM
the back of the cluster is from a us 90-91, my car is a 89 also.
i tried to do it the way you wrote it up but it didnt work for me.
what am i doing wrong??
the way you posted the write up did you do it right to left or left to right?
and the clip is facing up right.
on the dimmer switch? do you put the red-red/black -black together?
what about the rear defrost wires?
Old Jul 18, 2004 | 08:32 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmaxhardcorexx &raquo;</TD></TR><TR><TD CLASS="quote">the back of the cluster is from a us 90-91, my car is a 89 also.
what about the rear defrost wires?</TD></TR></TABLE>
I did it with the clip up, from left to right.
For the dimmer, I extracetd the red, and then the black, and slid them together. The pins can clip together if you extract them properly.
The rear defrost is not working right now, it will when I can get a 90-91 plug.
Ryan
