speedo freakin out
must be an older (93 or before) Integra w/ a speedo cable. If so, lube the cable w/ some graphite lube (in a small tube). My Camry and my friend's old 3rd gen Prelude used to do that, but graphite lube cleared it right up.
had a 94 gsr that did the same stuff.Tach would go crazy also.Ended up a surge protector in the bottom of the under hood fuse box.Had to replace intire box to solve the problem.I hit the junkyard.
sir_crx_says
Transmission & Drivetrain
Nov 21, 2013 09:39 PM
