need help asap if i am going to make niagra....
please only reply if you know what i am talking about.. otherwise it gets real confusing... no offense meant at all!
ok i am running this as obd1 using a conversion harness.
problem one!
i have two wires on the dx harness left that aren't connected. two white wires, one is "bundled" with a few other wires that i married into the distributor, the other wire is apart of the same bunch but runs along seperately. i dunno what these wires are.. on the distributor side i have two left hanging as well, a wire called ICM and CKPM so i need to know where these go as well.
here is a picture of the four wires i am talking about (the two on the top are the ICM and CKPM wires) :
problem two
are these the right gaskets to use to connect the down pipe to the exhaust manifold?
seen here:
problem one!
problem two
seen here:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">dont be a punk! how did u fix it? what did you do? what was the problem? COME ON!!!!!
yea i'd like to know too, since i was the silent tech here.
</TD></TR></TABLE>yea i'd like to know too, since i was the silent tech here.
JUNKIES 1
Apr 17, 2013 01:50 AM
CRXed
Nov 10, 2006 07:45 PM
