Rocks poked a hole in my Oil Pan. Whats best to do?? HELP!
Old Jul 7, 2004 | 06:57 PM
AspectIndustries's Avatar
Default Rocks poked a hole in my Oil Pan. Whats best to do?? HELP!
I just finally got my car boosted. StOOpid Construction trucks leaving crap all over the city!!@ and lucky me ran into a HUGE rock and Clunk! Popped a hole in my Oil pan, spilling Oil everywhere! Its parked at a friends house now, undrivable without any oil.
Whats your experience? Should I just put it on a lift and weld the crack?
Or should I remove the pan then weld it? ( Oil Pan are pain in the *** [damn bolts]! ) and buy another new gasket and on it goes again?
What possibilities of me ruining my car while welding the pan, on the car? Inputs will help...Thanks!
Old Jul 7, 2004 | 07:00 PM
dunkd's Avatar
i would just get a new one if its bad... if its not just try doing it with it still on the car... if it leaks, then take it off and weld it - its always worth a try to do it the easy way
Old Jul 7, 2004 | 07:17 PM
Default Re: (feri0)
Yea, I just want to get my car running. Its not so bad, but fixable. 1 cm crack?
I rather not get a new one.. To much hassle creating a new hole and getting a new return line fitting somewhere..... and weld that on...
Like they all say, once you boost. You be addicted! I miss it, and I want it now! -=P
Old Jul 7, 2004 | 07:21 PM
gritsak's Avatar
Default Re: (synik)
eitherway ide take it off...examine for anymore damage..then if it looks ok you could prolly get away with welding it....but if you have the funds just replace it...up to you.
B18EG6's Avatar
Default Re: (synik)
take the pan off.... make sure its clean before you weld it! If not for the safety during welding, you should at least check the pan for dirt or rocks or whatever you ran over! Check the pickup too
Old Jul 7, 2004 | 09:18 PM
Sunrise City Rider's Avatar
Default Re: (B18EG6)
The proper way to repair an Oil Pan is to weld it from the inside...
Old Jul 7, 2004 | 10:04 PM
_BEN_'s Avatar
Default Re: Rocks poked a hole in my Oil Pan. Whats best to do?? HELP! (synik)
Wouldint you have trouble welding the puncture if it was oily?
I would take the pan off for sure, clean it and weld it. Who knows maby where the rock hit it could have pushed in the pan a little and broke off your oil pickup.
Old Jul 7, 2004 | 11:13 PM
mattcalica's Avatar
jb weld is a great thing...
Old Jul 8, 2004 | 12:24 AM
jDMJeRk's Avatar
Default Re: (mattcalica)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcalica &raquo;</TD></TR><TR><TD CLASS="quote">jb weld is a great thing...</TD></TR></TABLE>
I was reading the thread waiting for someone to post my idea
jb weld is awesome for temp work
if it were me jb weld it for temp and buy a new pan asap wehter you dont want to or not
Old Jul 8, 2004 | 12:48 AM
thatguy's Avatar
buying a new pan would be the best remedy.
Old Jul 8, 2004 | 06:59 AM
Honda Hick's Avatar
Default Re: (jdmjerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjerk &raquo;</TD></TR><TR><TD CLASS="quote">
if it were me jb weld it for temp and buy a new pan asap wehter you dont want to or not</TD></TR></TABLE>
The thing is you're never going to get it perfectly clean in order to put the JB Weld on there or actualyl weld it. Some oil is always gonna be coming thru the crack. It's best just to pull it, clean it, and then have it welded up nice on both sides. It's not that big of a deal and it's going to have to be done at some point.
Old Jul 8, 2004 | 07:30 AM
MachAF's Avatar
JBweld it for now.
Old Jul 8, 2004 | 07:49 AM
JDMCRX's Avatar
Default Re: Rocks poked a hole in my Oil Pan. Whats best to do?? HELP! (MachAF)
**** it man pull it off wash it with brake Kleen and torch it after wards then clean the access then weld it thats the best way. take a pic of it
Old Jul 8, 2004 | 08:46 AM
integra-modder's Avatar
jb weld is a great <U>TEMPORARY</U> thing
Old Jul 8, 2004 | 11:16 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">take the pan off.... make sure its clean before you weld it</TD></TR></TABLE>
Good point there.. When I welded the return bung into my oil pan I didnt clean it and the oil caught on fire while I was welding..
Old Jul 9, 2004 | 11:50 AM
Default Re: (tgreaves)
Yea, I actually took off the oil pan last night. The pan was knocked/popped out.. and found a tiny crack/hole at the end of the pan, by the drain plug.
I just grinded off all the paint around it. Smooth it out a little.
And used a wirefeed (no gas) and welded 3 straight lines over it. Turned out better then I thought!! (noob at welding, but i got the BEADS!@)... Then I just welded on a skid plat of steel on front of the pan, just for extra security next time.
The oil pan gasket was like 1 week old. When removed, it looks good as new! No crushed looking or anything. So i reused it with no GLUE.. and it works out like a charm!! Hold oil fine!
And of course, a can of high temp paint to overall cover the mess.
iukaman
Jan 12, 2008 06:39 PM
PhilMac
11
Sep 14, 2007 06:23 AM
projectej8
11
Apr 3, 2005 02:45 PM
TheYellowDart
Dec 17, 2004 07:51 PM
98 Ek LsVtec
Jul 29, 2001 11:13 AM
