Is Greddy Safe to run on Stock block
Old Jul 7, 2004 | 04:40 PM
Austinbionic316's Avatar
Default Is Greddy Safe to run on Stock block
I have a quick question, Im debating on the swaps between the jdm b16 G2 swap or the JDM b18c swap for a beginner in FI, and I was wondering could I get a Greddy kit around 10psi on bone stock block around 300whp? would that be safe on either motor with Type R valvetrain?
Old Jul 7, 2004 | 04:43 PM
Bspec18's Avatar
Default Re: Is Greddy Safe to run on Stock block (Austinbionic316)
either block making 300hp on 10 psi with a Greddy kit seems too optimistic
Old Jul 7, 2004 | 04:48 PM
Adriano's Avatar
Default Re: Is Greddy Safe to run on Stock block (Bspec18)
you could make 300whp on a stock gsr with out any problem as long as you are tuned correctly. I dont think that the greddy kit will make more that 260-270whp at 10lbs.
Old Jul 7, 2004 | 04:49 PM
why do you say that?
Old Jul 7, 2004 | 04:50 PM
Default Re: Is Greddy Safe to run on Stock block (brryder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brryder &raquo;</TD></TR><TR><TD CLASS="quote">you could make 300whp on a stock gsr with out any problem as long as you are tuned correctly. I dont think that the greddy kit will make more that 260-270whp at 10lbs. </TD></TR></TABLE>
so in order for me to hit around 300whp+ which kit would u recommend for a beginner, cause I thought about Revhard, or Full Race, but I would like to keep my AC and p/s
Old Jul 7, 2004 | 04:57 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austinbionic316 &raquo;</TD></TR><TR><TD CLASS="quote">
so in order for me to hit around 300whp+ which kit would u recommend for a beginner, cause I thought about Revhard, or Full Race, but I would like to keep my AC and p/s</TD></TR></TABLE>
run the greddy kit, just boost more than 10psi, you'll make 300
Old Jul 7, 2004 | 05:00 PM
Default Re: Is Greddy Safe to run on Stock block (Mpir3)
well would that be safe for daily driving? because I wouldnt mind puttin down 240-300whp on a low psi with any kit, but my thing is this, people say the Greddy kits are like a GSXR 600 its fun for the first few months but then u wanna go faster, so would a Drag do fine for 240-300whp? cause I really wanna try and aim for 260-290 whp on a low psi.
Old Jul 7, 2004 | 05:03 PM
Bspec18's Avatar
for the amount of money spent on the greddy kit, i would consider other companies such as full race, rev-hard, or love-Fab. Although i don't recommend boosting more than 10psi w/o a proper fuel management system.
Old Jul 7, 2004 | 05:08 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austinbionic316 &raquo;</TD></TR><TR><TD CLASS="quote">well would that be safe for daily driving? because I wouldnt mind puttin down 240-300whp on a low psi with any kit, but my thing is this, people say the Greddy kits are like a GSXR 600 its fun for the first few months but then u wanna go faster, so would a Drag do fine for 240-300whp? cause I really wanna try and aim for 260-290 whp on a low psi.</TD></TR></TABLE>
why are you set on a "low psi", run the greddy kit and make your 300whp @ whatever psi it takes. The greddy will be fun for a street car.
Old Jul 7, 2004 | 05:09 PM
Nihilation's Avatar
Are there any users of the Greddy kit on here that make close to 300whp on a GSR engine?
Old Jul 7, 2004 | 05:13 PM
TurboJesse
Guest
Posts: n/a
Default Re: (Nihilation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nihilation &raquo;</TD></TR><TR><TD CLASS="quote">Are there any users of the Greddy kit on here that make close to 300whp on a GSR engine?</TD></TR></TABLE>
theres no reason it couldn't...the turbo can support ALOT more than 300whp.
Old Jul 7, 2004 | 05:23 PM
Default Re: (Mpir3)
i see
Old Jul 7, 2004 | 05:28 PM
Nihilation's Avatar
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">theres no reason it couldn't...the turbo can support ALOT more than 300whp.</TD></TR></TABLE>
Does a stock b18c1 force fed by the 18G Greddy kit with the Type 24 intercooler, 3" downpipe, 3" testpipe, full 3" exhaust, skunk2 manifold, 255 fuel pump, 440cc injectors and Hondata s100B(tuned by inlinePRO) sound like enough to make it on 10psi? Or a I dreaming, lol. Is 275whp more realistic?
Old Jul 7, 2004 | 05:29 PM
TurboJesse
Guest
Posts: n/a
Does a stock b18c1 force fed by the 18G Greddy kit with the Type 24 intercooler, 3" downpipe, 3" testpipe, full 3" exhaust, skunk2 manifold, 255 fuel pump, 440cc injectors and Hondata s100B(tuned by inlinePRO) sound like enough to make it on 10psi? Or a I dreaming, lol. Is 275whp more realistic?</TD></TR></TABLE>
i don't know about 10psi...but no reason it couldn't make it @ 12-14. Dont' limit yourself to a certain "psi", its rather meaningless.
Old Jul 7, 2004 | 05:34 PM
StolenTeg's Avatar
Default Re: (Mpir3)
It not the Psi that break the motor, it the power that it produced and the motor is unable to hold it... I only aimed for about 220whp on my greddy kit but this is on an LS and fully tuned hondata... shouldnt be that hard i dont think?
Old Jul 7, 2004 | 05:42 PM
m R g S r's Avatar
What happened to your orignal plan? I think tht setup was a lot healthier than a greddy kit.
GSR Block
Integra Type R Head
Integra Type R Intake and Exhaust cams
Arp headstuds
Full Race turbo kit
ITS 60-1 Turbo
HP racing sheet metal IM
Hondata S200b
Old Jul 7, 2004 | 05:45 PM
TurboJesse
Guest
Posts: n/a
Default Re: Is Greddy Safe to run on Stock block (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">What happened to your orignal plan? I think tht setup was a lot healthier than a greddy kit.
GSR Block
Integra Type R Head
Arp headstuds
Full Race turbo kit
ITS 60-1 Turbo
Hondata S200b</TD></TR></TABLE>
Maybe for making more power @ less boost...thats about it. Both setups are limited by the stock block. The greddy setup making 300whp would have a much more useablel powerband.
Old Jul 7, 2004 | 11:11 PM
GSR Block
Integra Type R Head
Arp headstuds
Full Race turbo kit
ITS 60-1 Turbo
Well with the way my money is going I just dont know quite yet
Old Jul 8, 2004 | 01:57 AM
mEr's Avatar
mEr
If i were going to buy a kit, i would look past Greddy to make that kind of power @10psi.....the only reason i would buy a greddy kit, is for that pretty blue sticker that says "this is legal"..Personally i would def. look into full race for 300HP stock Bottom end.....but like they said, do not limit yourself by PSI, it is pointless..and do not overlook tuning, it is your friend
Old Jul 8, 2004 | 04:58 AM
StolenTeg's Avatar
Default Re: Is Greddy Safe to run on Stock block (R...)
Yeah you could get 300whp on stock internal with great tuning, but remember that where the bottom end begin to cant hold anymore. i would get some piston/rod just to be on the safe side.
Old Jul 8, 2004 | 05:54 AM
tgreaves's Avatar
why are you set on a "low psi", run the greddy kit and make your 300whp @ whatever psi it takes. The greddy will be fun for a street car. </TD></TR></TABLE>
Correct..
Remember, Its not the psi that kills the motor its the amount of power its putting out and the fact that whatever motor cant support over a certant amount of power..
Old Jul 8, 2004 | 06:47 AM
Default Re: Is Greddy Safe to run on Stock block (StolenTeg)
but I wanna use the Type R valve train tho for the type R reving on a GSR block.
Old Jul 8, 2004 | 09:31 AM
Turbo E's Avatar
i made 224 WHP and 218 lb TQ on 7 psi
Greddy kit and Hondata S200 w/Skunk 2 camgears
Old Jul 8, 2004 | 11:09 AM
Default Re: (Turbo E 604)
on a stock block?
Old Jul 8, 2004 | 11:14 AM
Turbo E's Avatar
yah all stock internals.
click the sig for a dyno pic.
Oh BTW the greddy turbo can support up to 400 HP but getting there may be hard based on other bottlenecks of the kit.
you may want to upgrade to at least a 550 cc injector.
