weird noise when accelerating !!!
Old Jul 7, 2004 | 04:09 PM
1hotintegra's Avatar
Default weird noise when accelerating !!!
just started happening one day... it kinda sounds like if u get on ur car when its still cold...llike a whining kinda noise... anyone know what it could be?
Old Jul 7, 2004 | 06:20 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: weird noise when accelerating !!! (1hotintegra)
Could you be more specific? "Getting on your car when it's still cold" Hmm....that doesn't sound different to me.
High pitched? Low pitched? Dependent on wheel speed? Dependent on engine speed? Does it all the time?
Old Jul 7, 2004 | 07:51 PM
Default Re: weird noise when accelerating !!! (shamoo)
..high pitched.. (its hard to describe a noise)... kinda like a hissing noise of some sort.. depending on the engine rpm.. usually around 4-5, car def. feels more sluggish..
Old Jul 8, 2004 | 03:08 AM
Vsm Hatch's Avatar
could be brake pads wayyy past gone?
Old Jul 8, 2004 | 07:06 AM
Default Re: weird noise when accelerating !!! (LazyNip)
no its def. def. the motor... i can def. feel a power loss as well
Old Jul 8, 2004 | 07:39 AM
BlackThorN's Avatar
exhuast leak?
Ground loop in your stereo system?
Intake Leak?
Bearing gone bad?
Old Jul 8, 2004 | 08:33 AM
..::91TEG-G2::..'s Avatar
Default Re: (BlackThorN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackThorN &raquo;</TD></TR><TR><TD CLASS="quote">exhuast leak?
Intake Leak?
Bearing gone bad?</TD></TR></TABLE>
it might be that, cuz when i installed my amp's, it made that noise, but it was through the speakers.. kinda hard to notice where it was actually comming from, but i found out it was the speakers.
what about altanator? i know thats a shot in the dark, but i think i remember hearing someone talk about this in past thread's
Old Jul 8, 2004 | 09:09 AM
Fusion-X's Avatar
Default Re: (..::91TEG-G2::..)
i got the same problem, but mine happen around 3k rpm sound like metal clangin
Old Jul 8, 2004 | 09:20 AM
Quiks66's Avatar
Default Re: (Fusion-X)
It's probably an exhaust leak. Mine would make a real whiney noise (more noticeable while cold) up thru the RPM range. Found the leak and welded it shut. No more clangy whiney noise
Old Jul 8, 2004 | 11:17 AM
na not the stereo, im positive about that... damn i hope its not a bearing... that would suck...it really sounds like if u beat on ur car when its cold... or is it just my car that sounds diff. cold?
Old Jul 8, 2004 | 04:48 PM
taffetawhitegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">
how do u fix the ground loop problem?
Old Jul 8, 2004 | 07:24 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (1hotintegra)
Does the noise occur if you just rev? I'm thinking engine accessery.
Old Jul 9, 2004 | 03:47 PM
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Does the noise occur if you just rev? I'm thinking engine accessery.</TD></TR></TABLE>
engine accessery as in ....?
Old Jul 9, 2004 | 03:53 PM
shyboy817's Avatar
happened to mines after installing new deck, i think its bad ground, or my speaker wires n power wire are running too close to together..which they're not,..
Old Jul 9, 2004 | 03:59 PM
warrick's Avatar
Default Re: (shyboy817)
when exactly does it happen? during/right after a shift? does the whining change pitch?
Old Jul 9, 2004 | 05:18 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1hotintegra &raquo;</TD></TR><TR><TD CLASS="quote">
engine accessery as in ....?</TD></TR></TABLE>
PS pump, AC compressor, water pump, alternator
You said that there was a power loss associated with this noise. One of those components may have a worn bearing. Does the engine still rev freely?
Old Jul 9, 2004 | 06:06 PM
gsrboi80's Avatar
check your exhaust system sounds like you got an exhaust leak
Old Jul 10, 2004 | 09:35 AM
l4 soldier's Avatar
intake leak? my friend forgot to clamp down his intake after installation = ultra whiny
Old Jul 10, 2004 | 10:05 AM
shyboy817's Avatar
happens everytime i drive, not any certain time either, changes a little , a little louder at 3k..thot it was my bad ground but i tightened it
Old Jul 10, 2004 | 11:25 AM
dampachi's Avatar
check your plugs...
Old Jul 10, 2004 | 01:43 PM
Default Re: (warric_k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warric_k &raquo;</TD></TR><TR><TD CLASS="quote">when exactly does it happen? during/right after a shift? does the whining change pitch?</TD></TR></TABLE>
it happens all the time around 4-5k no matter if im shifting or not... def. def. def. not stereo.. i've had that that before and its not that...im clueless.. i hate this sh*t. anyway any more insight is def def a big help thanks
Old Jul 10, 2004 | 04:53 PM
changed plugs, checked ign. timing and did compression test today.... timign was a lil off but set to stock... compresstion test was about 230 accross the board.. is that a little high??
Old Jul 10, 2004 | 06:54 PM
Mythias's Avatar
its the clutch belt... happens all the time. here is a link to get a new one:
http://www.kalecoauto.com/general.htm
-Mythias
Old Jul 10, 2004 | 07:00 PM
No's Avatar
No
My intake whistles around 3.5-4 or so.Prolly that?
Old Jul 11, 2004 | 05:12 AM
Default Re: (narib2oo1)
def. def. not a intake whistle i know what that sounds like.... what is a clutch belt i've actually never heard of that before?
