Whats your da's(90-93) tegs 1/4 time???
Old Jul 7, 2004 | 03:28 PM
KiNG $h!t's Avatar
Default Whats your da's(90-93) tegs 1/4 time???
whats your da's (90-93) 1/4th time and whats the setup??
Old Jul 7, 2004 | 05:51 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Default Re: Whats your da's(90-93) tegs 1/4 time??? (this guy 2fast)
17.2 just intake at 5200+ feet(corrected is low 16's)
90 5 spd RS with 170K miles
Old Jul 7, 2004 | 08:29 PM
KiNG $h!t's Avatar
damn good thing im not that much above sea level time look so bad when you are
Old Jul 7, 2004 | 08:57 PM
t . b o z's Avatar
Default Re: (this guy 2fast)
I dunno what mine is, but Ive pulled on mid/low 15 second civics...and Im stock...so who knows.
Old Jul 7, 2004 | 10:00 PM
KiNG $h!t's Avatar
koo any b16 da tegs out there with times?
Old Jul 7, 2004 | 10:04 PM
3.504's Avatar
ran a 10.38 1/8th w/ i/h/e and skunk2 IM. ran a 9.55 same set up plus 50 shot. got a b16 in the mail, put it in, went to ohio... ran a 1/4 up there. went 16.4 w/ a 10.71 1/8th because the b16 came with a bad clutch... slipped that thing the whole way down.
Old Jul 8, 2004 | 02:34 AM
jdm_lover's Avatar
my time down there
.530 - reaction
2.31 - 60ft but i guess its ok...
9.901 - 1/8mile
71mph - 1/8mile
15.33 - 1/4mile
89.4mph - 1/4
i guess im happy with my time
Old Jul 8, 2004 | 03:48 AM
PizzaBoy's Avatar
In my 91 XSi (I live in new zealand, the land of JDM imports ) I have done 15.101 @ 92mph with a 2.4 60ft (our tracks are crap) with just pod and custom 3" cold air intake, and semi stripped out.
I have done 14.9 but the timing system didnt give me a trap speed
Old Jul 8, 2004 | 09:21 AM
KiNG $h!t's Avatar
14.9 is very impressive for being close to stock
Old Jul 8, 2004 | 03:51 PM
KiNG $h!t's Avatar
bump
Old Jul 8, 2004 | 06:20 PM
hybridls's Avatar
14.4 with crower 404z and b16 tranny. This is a LS motor
Old Jul 8, 2004 | 06:51 PM
KiNG $h!t's Avatar
damn thats a nice time no b16 or lsvtec guys out there?
Old Jul 8, 2004 | 07:09 PM
3.504's Avatar
the guy that posted w/ the xsi is a b16 and he ran low 15's/high 14's... which is normal. i have a b16 and i have a bad clutch that i can't really do anything with till i replace it. i ran a 16.4 slippin clutch all the way down, vtec on a switch, and 7k rpm because i run a stock pr4.
Old Jul 8, 2004 | 08:10 PM
Frankintegra's Avatar
91 LS Teg /I/H/E XGT-V michelin Stock Weight
60 ft 2.362
1/8 10.271
mph 68.87
1/4 15.946
mph 87.51
I have done the LS/VTEC and my friend has the 2.4 PT Turbo with Stage 1 from MoPar and I can put some cars between him and me ! He will do 14.6 in the 1/4 . I will be going to the track soon and will post the times later! Also Check out
http://www.dragtimes.com
and
http://www.hondashowoff.com/profile.php?id=2513
http://www.hondashowoff.com/ga..._id=2
Old Jul 8, 2004 | 08:31 PM
Eviloliv3's Avatar
Default Re: Whats your da's(90-93) tegs 1/4 time??? (Frankintegra)
my best so far is a 15.82 @86 in a stock 91 LS with only exhaust. i also had bad compression in the 3rd cylinder, but since then ive put on a new head along with some other goodies, and im actually going to the track after work tomorrow, ill post up video/pics/times when i get home
Old Jul 8, 2004 | 08:48 PM
jdm_lover's Avatar
woo whoo...like what i say...Ls power...man...all i need now a b16 or ITR tranny....wheres the mONEY!!
Old Jul 8, 2004 | 09:09 PM
KiNG $h!t's Avatar
damn you ls guys pull some pretty nice times now lets hear from some more lsvtec guys
Old Jul 9, 2004 | 11:19 PM
Eviloliv3's Avatar
just got back...
this heat is killing me
i ended up with a 15.8 @ 88mph
same time, higher trap speed, probably about 30-40 degrees hotter outside. everybody was running shitty
Old Jul 10, 2004 | 12:21 PM
KiNG $h!t's Avatar
still a fairly nice time for a ls in a 2700 pound car
Old Jul 10, 2004 | 06:10 PM
Eviloliv3's Avatar
g2s weigh a lot less than that, plus my car was gutted from the door panels back. i had the dash, driver seat and both door panels on, other than that, everything else behind me was gone. im also at like 1500 feet above sea level
Old Jul 10, 2004 | 06:29 PM
KiNG $h!t's Avatar
im pretty sure g2s weigh in close to 2700 maybe like 26sumtin
Old Jul 10, 2004 | 08:00 PM
Goinfasterthanu's Avatar
15.0 off the bottle....14.5 on it slipping clutch the whole way down....
i/e/h/ hiflow cat/p&p intake manifold/ gutted fully/ civic hx wheels/ 18psi tire press/55 shot zex with low *** bottle pressure{700psi}
Old Jul 10, 2004 | 08:05 PM
KiNG $h!t's Avatar
with a better clutch you will see low 14s
Old Jul 10, 2004 | 09:12 PM
3.504's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by this guy 2fast &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure g2s weigh in close to 2700 maybe like 26sumtin</TD></TR></TABLE> 2556 is the weight of the lightest DA, the RS... the LS/GS are both a little over 2600lbs. http://www.g2ic.com has all the stats if you wanna look for yourself
Old Jul 10, 2004 | 09:20 PM
KiNG $h!t's Avatar
yea i knew most were in the 2600 area close to 27 but yea either way there still boats lol
