RC ENGINEERING FUEL INJECTORS - from $289 DELIVERED
Looking for a Top of the line injector setup??
Special is for the RC Engineering Saturated Injectors (the 11-14 ohm) for the B, D, and H and K Engines.
310cc or 440cc inectors for $319 Delivered (set of 4)
and the 550cc and 750cc injectors for $349 Delivered (set of 4)
Injector wiring clips are necessary for all 96+ Honda/Acura vehicles and are available seperatley for $19/set of 4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeprhatch »</TD></TR><TR><TD CLASS="quote">
you bastard where were you last week
I second that.
</TD></TR></TABLE>I second that.
Mostly for obd 1 and 2. Check if you have a resistor box. If you do you need peak and hold injectors, or remove the resistor box for saturated injectors.
Will the 750cc injectors fit an AEM fuel rail and OEM Integra GSR injector seals?
How long you gonna be offering this?
These should fit just like OEM injectors fit.
This is a good deal, how long are you keeping this going?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> you bastard where were you last week ...
Sorry
Sorry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ehron »</TD></TR><TR><TD CLASS="quote">
I second that.</TD></TR></TABLE>
Double
Double
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djay86 »</TD></TR><TR><TD CLASS="quote">is saturated for obd0- or obd1 or obd2?</TD></TR></TABLE>
The reply:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Mostly for obd 1 and 2. Check if you have a resistor box. If you do you need peak and hold injectors, or remove the resistor box for saturated injectors.</TD></TR></TABLE>
That is indeed correct. Thanks !
Tom
The reply:
Tom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightning »</TD></TR><TR><TD CLASS="quote">
Sorry
saaaaaaarrright
Sorry
</TD></TR></TABLE>saaaaaaarrright
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">Will the 750cc injectors fit an AEM fuel rail and OEM Integra GSR injector seals?
How long you gonna be offering this?</TD></TR></TABLE>
answered with:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> These should fit just like OEM injectors fit.</TD></TR></TABLE>
Indeed correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">This is a good deal, how long are you keeping this going?</TD></TR></TABLE>
It is currently an open ended deal for HT members. Thanks,
Tom
answered with:
Indeed correct.
Tom
i am interested in 440 cc injectors for my 00 prelude how much and which ones do i need? please reply back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">Is there any deal like this for Peak and hold injectors as well? .</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">Is there any deal like this for Peak and hold injectors as well? Loooking for either 650 or 750.</TD></TR></TABLE> Nothing right now for the 650 and 750 Peak/Hold. Thanks,
Tom
Tom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22a4 »</TD></TR><TR><TD CLASS="quote">i am interested in 440 cc injectors for my 00 prelude how much and which ones do i need? please reply back</TD></TR></TABLE> that would be the 440 Saturated with clips. $275 delivered. In stock. Thanks,
Tom
Tom
</TD></TR></TABLE>Sorry nothing for the P/H right now. Thanks,
Tom
Tom
i need some saturated injectors for my 93 hatch. i have a walbro fuel pump and greddy turbo intercooled. which size should i get. i was thinking 310cc or 440cc which would be better im only boosting 6-8 psi.
Go with the 440s, they will give a little room for growth. 310s will be peaked out at around 200HP. Thanks,
Tom
Tom
Sorry, not running the Peak/Hold on special right now. Thanks,
Tom
Tom
