Cheaper Tranny Fluid same as Gm syncromesh
Old Jul 7, 2004 | 11:41 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Cheaper Tranny Fluid same as Gm syncromesh
Since Gm and Bg synchromesh are the same, I would like to tell you people about something that is the same and only 5 bucks a quart.
It's pennzoil syncromesh, I put this in my b16 hatch and it worked wonders on the tranny.
Only 4.99 at autozone.
Old Jul 7, 2004 | 11:56 AM
nousername's Avatar
Default Re: Cheaper Tranny Fluid same as Gm syncromesh (MugenHonda)
Just an FYI
I read a pretty techincal post on HT earlier this month saying the syncromesh fluids wear a little harder on your tranny then the regular Honda MTF. Supposedly they cause harder wear and tear on your tranny internals because of the additives used in the oil.
I'm not saying not to use the Syncromesh, but I would do some research and see what applications it is best suited for. (track, daily driver, autox).
Old Jul 7, 2004 | 01:33 PM
StupidSlowRSX's Avatar
Default Re: Cheaper Tranny Fluid same as Gm syncromesh (nousername)
... This is true, due to the fact that GM and other domestic companies usually use heavy weight gear oil ex: 75w-90..
where as HMT is something like 5w-30
There is a difference... Dont use syncromesh...
HMT fluid
Old Jul 7, 2004 | 05:07 PM
Jester88Si's Avatar
Where can I get this infamous honda MTF?
Old Jul 7, 2004 | 05:16 PM
B2FiNiTY's Avatar
Default Re: (Jester88Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jester88Si &raquo;</TD></TR><TR><TD CLASS="quote">Where can I get this infamous honda MTF? </TD></TR></TABLE>
HONDA or ACURA
The really good stuff people should be getting over the GM stuff is syncromesh modified!
Old Jul 7, 2004 | 05:18 PM
crxgator's Avatar
ford dealerships...
Old Jul 7, 2004 | 05:59 PM
Jester88Si's Avatar
Default Re: (crxgator)
h-t needs a sarcastic emoticon...
Old Jul 7, 2004 | 06:05 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Cheaper Tranny Fluid same as Gm syncromesh (StupidSlowCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX &raquo;</TD></TR><TR><TD CLASS="quote">... This is true, due to the fact that GM and other domestic companies usually use heavy weight gear oil ex: 75w-90..
HMT fluid </TD></TR></TABLE>
so what weight is the penzoil syncromesh?
Old Jul 7, 2004 | 06:11 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jester88Si &raquo;</TD></TR><TR><TD CLASS="quote">h-t needs a sarcastic emoticon... </TD></TR></TABLE>
yes, we need the rollseyes icon...
i would be such a ***** with that...
Old Jul 7, 2004 | 06:19 PM
daidilus's Avatar
what are you all you people nucking futs???
honda says put 10w30 motor oil in tranny because that is what it is made for......
Old Jul 7, 2004 | 06:23 PM
wtsexton's Avatar
I don't know about you but I don't like the idea of just putting 'motor oil' in my expensive LSD cable trans.
Old Jul 7, 2004 | 06:41 PM
Default Re: (wtsexton)
Honda MTF ( Manuel Transmission Fluid )
guess what... its made for Manuel tranny's.
Old Jul 7, 2004 | 07:04 PM
HNDAPWR's Avatar
Default Re: (StupidSlowCRX)
I use Redline MTL, never had a problem in over 100,000 miles. Its a 99 Si hydro too, which i've been told, "has bad synchro's".
Old Jul 7, 2004 | 10:43 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Cheaper Tranny Fluid same as Gm syncromesh (Hybrid Hatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Hatchback &raquo;</TD></TR><TR><TD CLASS="quote">
so what weight is the penzoil syncromesh?</TD></TR></TABLE>
Old Jul 8, 2004 | 03:42 AM
am I a book or somethin? Go to the damed store and look on the bottle....
Old Jul 8, 2004 | 12:39 PM
daidilus's Avatar
umm are you are a honda engineer? they designed them to be used with 10w30 motor oil.....but i guess if you beat on your car, and always tear **** up..you need more protection..i guess the honda engineers did not mean for them to get beat on like we beat on them too eh...
Old Jul 8, 2004 | 10:05 PM
spcrxracer's Avatar
Default Re: (daidilus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus &raquo;</TD></TR><TR><TD CLASS="quote">umm are you are a honda engineer? they designed them to be used with 10w30 motor oil.....but i guess if you beat on your car, and always tear **** up..you need more protection..i guess the honda engineers did not mean for them to get beat on like we beat on them too eh...</TD></TR></TABLE>
He Prolly doesnt have a girlfriend so that's not the only thing he is used to beating......If you know what i mean.
Old Jul 8, 2004 | 11:01 PM
Nerologic's Avatar
Default Re: (spcrxracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">Since Gm and Bg synchromesh are the same, I would like to tell you people about something that is the same and only 5 bucks a quart.
Only 4.99 at autozone.</TD></TR></TABLE>
what state are you in? i coudlnt find any in Ca's autozones, i couldnt even special order it ....
Old Jul 8, 2004 | 11:37 PM
guttedEF's Avatar
https://honda-tech.com/zero...age=7
Old Jul 9, 2004 | 02:14 AM
Default Re: (guttedEF)
http://www.stealth316.com/2-pe...h.htm
Old Jul 9, 2004 | 02:56 AM
REX VT's Avatar
10w40 semi synthetic
Old Jul 9, 2004 | 05:52 AM
Fred.Rodgers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX &raquo;</TD></TR><TR><TD CLASS="quote">http://www.stealth316.com/2-pe...h.htm</TD></TR></TABLE>
great link, thanks a lot
sixtoek
Oct 31, 2011 03:11 AM
girliehonda
Mar 2, 2006 03:01 PM
xd69
Jun 18, 2005 10:51 AM
P1mpSlap
Mar 15, 2003 03:28 PM
EF-9SiR
10
Nov 3, 2002 07:57 AM
