b series intake on a d series motor?
Old Jul 7, 2004 | 10:26 AM
99eciVic's Avatar
Default b series intake on a d series motor?
I have a 99 civic ex with the stock d16y8 motor, my question is does anyone know if a b series (most likely b16) aftermarket intake would fit on my motor and in my bay, I honestly don't see why it wouldn't, but would like to know for sure before i go out and get one, I ask b/c I want the j's racing intake, but all i see is the j's for a b series motor...anyone who knows this it would be greatly apprecated
Old Jul 7, 2004 | 10:28 AM
barto's Avatar
Default Re: b series intake on a d series motor? (99eciVic)
im pretty sure it will if not positive. cause all you have to do is use the hose clamp thing to attach it to the TB. makes sense to me
Old Jul 7, 2004 | 10:34 AM
99eciVic's Avatar
Default Re: b series intake on a d series motor? (barto)
yeah, tahts what i figured....i don't know if theres something i don't know bout diff. sensors or vacuum lines on the b series, i could understand if it was a dx motor...
Old Jul 7, 2004 | 10:41 AM
null.'s Avatar
well only difference would be the diameter of your TB and the diameter of the intake. but with some custom fabrication you can do anything
Old Jul 7, 2004 | 11:51 AM
110 South's Avatar
The cylinder head bolt pattern for the intake manifolds are entirely different from each other on a D-series vs. B-series. It will not fit and if it did, it would most likely cause a loss of low end torque on a stock bottom end.
-Brandon
Old Jul 7, 2004 | 11:53 AM
skunk2eg's Avatar
Default Re: b series intake on a d series motor? (110 South)
all it is is piping and a filter... i did the reverse, a 94 ex intake (from my old motor) on a b18b, it works just fine
Old Jul 7, 2004 | 11:56 AM
99eciVic's Avatar
i'm talking about changing the intake, it sounds like your talking about the intake manifold
Old Jul 7, 2004 | 12:02 PM
SOHC50shot's Avatar
it will work, it might take some dickin around like egb18tubro said, but it definatly will work. I got a AEM cold air for free from a friend with a b18, and i just cut it to fit as a short ram, and it works perfect..
Old Jul 7, 2004 | 12:14 PM
skunk2eg's Avatar
Default Re: b series intake on a d series motor? (SOHC50shot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99eciVic &raquo;</TD></TR><TR><TD CLASS="quote">i'm talking about changing the intake, it sounds like your talking about the intake manifold</TD></TR></TABLE>
i was talkin about the cold air.... it will fit onto the manifold
Old Jul 7, 2004 | 12:27 PM
jerbear!'s Avatar
as long as it aint the a gsr. the manifold on that is different. unless u were to by an aftermarket IM then it would fit. but b16 would bolt up just fine
Old Jul 7, 2004 | 12:59 PM
Frozen E's Avatar
H-T White Ops
People.....He's talking about the intake TUBE. Not the whole intake manifold.
You might have to do a little bit of work with a hacksaw if push comes to shove but I don't see why it wouldn't work.
Old Jul 7, 2004 | 01:06 PM
CivicVX94's Avatar
http://store.dragracing.com/pr...#apps
there you go. it's cheaper than J's, and its the same thing, plus it's made for D's so there's no guessing, it will fit
Old Jul 7, 2004 | 01:39 PM
deeksmooth's Avatar
Default Re: b series intake on a d series motor? (CivicVX94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">http://store.dragracing.com/pr...#apps
there you go. it's cheaper than J's, and its the same thing, plus it's made for D's so there's no guessing, it will fit </TD></TR></TABLE>
yeh if they have them in stock... i gave up and retracted my order after waiting 1.5 months.
Old Jul 7, 2004 | 09:14 PM
CivicVX94's Avatar
Default Re: b series intake on a d series motor? (citrEK)
huh...good to know, did you find another site to buy a knock off J's from?
Old Jul 8, 2004 | 03:37 AM
99eciVic's Avatar
also if theres a black one out there, not too hot about the red, blue, and yellow, thanks for the link thoguh, i've seen flat black ones instead of the c/f ones that look really good...any help has and will be greatly appreciated
Old Jul 8, 2004 | 03:39 AM
99eciVic's Avatar
Default Re: b series intake on a d series motor? (skunk2eg)
sorry skunk, your second post, i was referring to 110 south's answer
Old Jul 8, 2004 | 05:38 AM
urzaofusn's Avatar
there are a ton of converters pieces, so i would think that it would be accomplishable
_Em1
Jan 30, 2014 11:54 AM
hondakid4dr
Mar 11, 2008 09:05 PM
scorpnaz
Feb 12, 2006 10:57 PM
