ls crank question...
Hey guys, I have an lsvtec motor going in a crx- I can't freakinn wait!!! And my buddy who is into big block chevy's had told me that I should get the throws on my crank "shaved" to whip through the oil faster.. Has anyone heard of this before?? And if so would they recomend it...
MAYBE he is refering to knife edgeing the crank. my d series isnt worth it but maybe if you are going with big numbers you could c onsider it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmonee112 »</TD></TR><TR><TD CLASS="quote"> And my buddy who is into big block chevy's had told me that I should get the throws on my crank "shaved" to whip through the oil faster.. </TD></TR></TABLE>
Hmmmmmmmmm. Lets see....the oil is in the oil a pan seperates the crank from the oil. So what are you actually cutting through? If you wanted to make your crank lighter and balanced, then thats another issue. You are not actually cutting through oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmonee112 »</TD></TR><TR><TD CLASS="quote">Hey guys, I have an lsvtec motor going in a crx- I can't freakinn wait!!! And my buddy who is into big block chevy's had told me that I should get the throws on my crank "shaved" to whip through the oil faster.. Has anyone heard of this before?? And if so would they recomend it... </TD></TR></TABLE>
knife edging is what he is referring to, its less weight on the crank so the crank will spin up faster (less rotational mass) just make sure you balance the crank by itself and then balance everything as a system before you run a knife edged crank
I would knife edge a crank on a daily driver.Theres just too much harmonics going on in an engine,and the counter weights also act as a dampner.Drag cars have a hard enough time with knife edged crank.There usually isnt too much oil for the crank to slice through,but it does help the counterweights cut through the windage.If you do take off weight,dont do more than 2 lbs,and make sure the crank gets balanced with the crank pulley and flywheel you plan on using.
