18x8.5 wheel on 2004 Accord Sedan?
I want to put a 18x8.5 wheel on my '04 Accord. I am not too knowledgeable on wheels and tire sizes. I don't want the car to rub. Is this possible? And if so, what size tires would I need and what offset?
THANKS
Jason
THANKS
Jason
They will fit, whether or not you need low profile tires, i dont know. The only trouble I see you getting into with 18s is lowering the car, if you dont plan on doing that you should be ok and probably wont have any tire rub inside the wheel well.
yes they will fit with 225/40/18 or 235/35/18 tire. also the offset on ur wheels have to be a little lower than normal. and you can lower your car also.
AccordInTheMaking
Sep 30, 2006 03:56 PM
