The search for dust boots continues....
I have posted this in the Integra and ITR forums, but I know many people in this forum swear by the Koni/GC combo, so I'm asking here:
I installed my Koni Ground Controls last week, and I tried to find something to cover the shock piston since the stock dust covers won't work as intended w/ coilover springs. So after searching I found this pic from JonsteR:
He said he got them from AutoZone, so I went there, and the only thing they had was this:
I fit this universal rack and pinion boot over one of my shocks, and it seem to fit pretty well, but it seemed to fit pretty tightly inside the spring. I pretty much had to force the boot inside the spring. I'm not sure if that would work very well w/ the movement of the spring all the time while driving.
Has ANYBODY found ANYTHING that I can use to cover the entire shock piston? Cutting the stock covers as GC recommends is pointless and renders the stock dust covers useless. Has anyone seen a company making full adjustable coilovers w/ dust boots that I might be able to get the dust boots separately?? TIA
Why do you say that cutting the stock covers it useless?
I'm assuming the DC2 is the same as the DA: you jut sneed to rebore the shaft opening at the top and it should fit. You have clearance issues with your springs?
I have been too lazy to put some on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">What the hell's a dust boot?
It's a northeast road salt blocker
</TD></TR></TABLE>It's a northeast road salt blocker
i8 went to a local part store that rebuolds steering racks, i sized up a boot just right inner diameter and length. but because of my upper mounts, the boot is sandwiched betweent he bumpstop and the shock. i'll get pics sometime soon but it looks exactly like the pics above. the fitment was just right, once it was on the shock body, spring was fitted perfectly without snagging the boot. unfortunately it cost me 13 a pop
I got those ones from AutoZone to work, check out my how-to https://honda-tech.com/zerothread?id=917766
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">shaft, rod, piston, it's all the same
Engine, transmission, differential...it's all the same
</TD></TR></TABLE>Engine, transmission, differential...it's all the same
I seem to recall, from my cycling days, a shock boot for mountain bike forks that was a neoprene type material, clipped on the top and bottom, it snugged up to the shaft and compressed/extended as necessary. I believe it was made by a company called Lizard Skinz
you might want to look into that...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Lee »</TD></TR><TR><TD CLASS="quote">
huh?
</TD></TR></TABLE>huh?
huh?</TD></TR></TABLE>
He's just point out how they aren't the same.
So you're saying the part that sticks out above the shock body and goes inside when the shock is compressed is not the shock piston, but another separate part from the shock piston? Whatever, I was trying to illustrate a point which I think most people understood, not get the exact correct terminology.
You may be able to source what you're looking for at a motorcycle shop. They use the accordian style dust boots for the exposed front forks of motocross bikes. Just have to find a set that fit the necessary upper and lower diameters....length won't be an issue.
robert j.
robert j.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power »</TD></TR><TR><TD CLASS="quote">
It's a northeast road salt blocker</TD></TR></TABLE>
hahah ill attest to that.
may the salt burn in hell.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zc911 »</TD></TR><TR><TD CLASS="quote">got any 4x4 shops around you?
They should have a variety of dust boots</TD></TR></TABLE>
Yeah, but everything 4x4 related is MASSIVE compared to our little Hondas. The dust boots I saw at a local store were almost 3" diameter and probably 14" long.
i have never ran dust boost's although im in california so no real need to. for some reason i thought you were too. and now with my koni/gc setup i couldn't run them if i wanted too.
Have any of you tried the dust boots made by Energy Suspension? They're only $7.39 a pair from summit racing. My GCs are going on soon, so I'm thinking about ordering them but not sure if they'll fit or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asmallsol »</TD></TR><TR><TD CLASS="quote">what about getting some dust boots for 4 wheels or 4x4's. I know there are 098450834 diffrent ones for them.</TD></TR></TABLE>
4x4 shock dust boots are massive, about 3" diameter and 14" long on most of them.
A friend mentioned trying a 4x4 steering stabilizer boot, as it's smaller than a shock dust boot.
