i NEED these two bolts ASAP
sorry for the caps but it truely is an emergency.....
i need number 24 it doesn't show the lower bolt but i need both of them , acura lists these as being BOLT, HEX. (12X61) is this all the info i need to get these from a hardware store? i assume they are fine thread, but do i need the thread pitch as well?
if anyone out there can lend a hand on identifying these two lil bastards so i can get them locally that would rock.... or if u happen to live in NY and have a set GET AT ME!!
thanks guys!
thanks guys!
take the 12x61 to a hardware store and pick up a couple. i had to do that several times. They may not have the large hex heads on them but they will work. I probably have some of them out in the garage, but not sure and not really worth diggin for when you can get them locally.
Hope this helps.
Hope this helps.
