fuel filter
Old Jul 6, 2004 | 10:43 AM
REVOUTHIGH's Avatar
Default fuel filter
I just bought a 89 civic for a toy and I wanted to do a tune up on it. i changed the spark plugs and the fuel filter but when the fuel pump starts it leaks bad at right fitting(to the engine from the filter). I know the bolt has two holes in it, i dont know if i have to line them up or just tighten the hell out of it. any help would be appreciated.
Old Jul 6, 2004 | 10:47 AM
DXDOHCVTEC's Avatar
On each side of the fitting there should be a washer it is good to replace the washers each time you loosen up on the fitting. Otherwise you do have to tighten down real good or try flipping the washer over.
Old Jul 6, 2004 | 10:51 AM
APEX CRX's Avatar
Default Re: fuel filter (REVOUTHIGH)
I'd replace both crush washers on the fittings
Old Jul 6, 2004 | 11:32 AM
REVOUTHIGH's Avatar
Default Re: fuel filter (APEX CRX)
the fuel filter came with two but no instructions so i just thought one goes on the bottom of each, to and from.
.Hatches.
Mar 17, 2008 05:53 PM
WayneGro
Oct 24, 2003 04:58 AM
get wet racing
Jan 6, 2003 06:16 AM
CivilizedCiv
Aug 22, 2002 08:22 AM
AK94GSR
Aug 7, 2002 08:02 PM
